BFG radial tire pressure? - Team Camaro Tech
post #1 of 5 (permalink) Old May 27th, 09, 06:07 PM Thread Starter
I'm just curious what others have found to be a good pressure to run BFG radials at. I don't know what is recommened but I've been using about 34psi. That's kind of bumpy on the potholed roads around here but I don't like much sidewall flex.
Anybody?
Melrose RS is offline
post #2 of 5 (permalink) Old May 27th, 09, 09:47 PM
Eric
Re: BFG radial tire pressure?
I emailed BFG about this a while back and they said to stay with what the stock recomended pressure was. I can't remember now, does 24 psi sound right. I know it's on the sticker on the glove box door.
ERIC
67 Convertible, 350CID, TKO600RR, 3.73 Eaton Posi
ept000 is offline
post #3 of 5 (permalink) Old May 28th, 09, 03:53 AM
BILL
SPARKY69's Avatar
I run 34 in the front and 36 in the rear!! 24 is way to soft!!
SPARKY69 is offline
post #4 of 5 (permalink) Old May 28th, 09, 04:56 AM
67 Convertible's Avatar
I run 35 psi on all four.
'67 Marina Blue Convertible. L30, PG. All numbers match, 41k original miles.
"The only time you have too much fuel, is when you're on fire"
67 Convertible is offline
post #5 of 5 (permalink) Old May 28th, 09, 05:24 AM
Den
DenRS's Avatar
I run 32 psi in every car I own
DenRS is offline
