68--RR tire rub - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 1st, 09, 06:34 AM Thread Starter
68--RR tire rub
car has a pair of 255-60-15 on the rear that rub on corners and bumps(RR is the only one that seems to rub)The wheels are 7 inch ralleys with 4 1/4 inch backspace. my first inclination was to get two smaller tires, but I have a matched set of firestone firehawks that are still like new. If I find two ralley rims for the rear with say 4 1/2 or 4 3/4 backspacing will this cure my problem. Can anybody tell me what cars came with more backspacing? thanx wnk.
dusted800 is offline
post #2 of 5 (permalink) Old Jun 1st, 09, 08:19 AM
TC
Re: 68--RR tire rub
Is you rear lowered from stock? I run 15x8 with same bs and have no problems with the same tires. Are your springs wore out?
1968 Camaro RS orig AC car, ZZ Fatburn, Doug's D368 Headers, Tremec TKO600 w/ Hurst Blackjack, 12 Bolt Posi 3:73 mulitleaf, SFC's, Budniks, Hotchkis, Magnaflow, etc
6Z8RS is offline
post #3 of 5 (permalink) Old Jun 1st, 09, 11:15 AM Thread Starter
Re: 68--RR tire rub
no, rear isn't lowered, as a matter of fact it is a 5 leaf 12 bolt that I have been toying with the idea of taking a couple leafs out to see if it would ride better.
post #4 of 5 (permalink) Old Jun 2nd, 09, 02:47 PM Thread Starter
Re: 68--RR tire rub
anyone??
post #5 of 5 (permalink) Old Jun 2nd, 09, 09:24 PM
Jeff
Re: 68--RR tire rub
I'm not aware of any original-appearing 15x7 rally wheels with more backspacing than you've already got.
Because the rub is happening on just one side, I would crawl underneath with a tape measure and check how much space you've got between the tire and the inner fender-well on both sides in the back. If the dimensions from the right side and the left side of the car are quite a bit different, then maybe your differential is sitting further over towards the right side and causing the rub.
Just a thought.
-Jeff
JeffD is offline
