Why are my tires wearing out in the middle? - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 4th, 09, 10:02 AM Thread Starter
Patrick
I have always had problems with my 295/50's wearing out just in the middle. My rim is 10'' wide. I usually put 30-35lbs of air in the tire. Why is this happening and how do I fix it?
This is on my rear tires.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #2 of 8 (permalink) Old Jun 4th, 09, 10:09 AM
Jerry
Re: Why are my tires wearing out in the middle?
Sounds like the rim is wide enough, only thing I can think of it too much air pressure. Maybe your gauge is off?
69 Z11 03D Van Nuys
82 Z28 Gordon Johncock's Pace Car
97 30th Z28 6 speed vert 1 of 175
69 z11 is offline
post #3 of 8 (permalink) Old Jun 4th, 09, 10:36 AM
Banned
Ron
Badbird's Avatar
That's caused from over inflation!....You're running too much air!....Cut it down to 25-28 psi.
Badbird is offline
post #4 of 8 (permalink) Old Jun 4th, 09, 10:45 AM
Lee
Keep in mind as you drive and the Tire heats up, on a tire that big, it will gain at least 5lbs per tire maybe more.....as suggested....go down to 25lbs.
canX11 is offline
post #5 of 8 (permalink) Old Jun 4th, 09, 01:36 PM
Mickey
Moonpie's Avatar
What Badbird said. Overinflation wears the middle, underinflation wears the outsides causing "cupping".
Wider tires usually need less air than narrower ones. 24-25 lbs. good place to start.
Moonpie is offline
post #6 of 8 (permalink) Old Jun 4th, 09, 05:13 PM Thread Starter
Patrick
Thanks guys, I'm going outside right now and lowering them to 25.
383 IS SOLD!
Building a 489BBC
post #7 of 8 (permalink) Old Jun 5th, 09, 12:05 PM
Dr. Feelgood
too low,they'll feel like mush.30-32lbs should be fine if 35 is too much.
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
post #8 of 8 (permalink) Old Jun 17th, 09, 07:47 AM
Nameless wonder
stop doing burnouts, im just sayin
Cant seem to climb out this money pit they call Camaro
lv42day is offline
