Early 80's Monte Carlo wheels... fitment? - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 5th, 09, 03:38 PM Thread Starter
Guess
HwyStarJoe's Avatar
I found a set of 15" Monte Carlo Rallys ($50) and was wondering if the backspacing will give me any trouble?
I just want a cheapo set of wheels that won't look stupid until I shake the car down and can afford 17's. I figure I can't go wrong for $50 but want to make sure they'll at least look right first.
Yes, no...maybe?
HwyStarJoe is offline
post #2 of 3 (permalink) Old Jun 5th, 09, 04:21 PM
Banned
Ron
Badbird's Avatar
Re: Early 80's Monte Carlo wheels... fitment?
You should be OK!....I had a set of those on a 71 Chevelle Malibu I once had only mine were 14" wheels with plastic trim rings!, I think the backspacing the car called for was 4 1/2" but I'm not sure what the backspacing is on those wheels but they looked OK!
Badbird is offline
post #3 of 3 (permalink) Old Jun 8th, 09, 06:55 AM Thread Starter
Guess
HwyStarJoe's Avatar
OK... change of plans.
I found and picked up a set of 15x7 Cragars.... but the backspacing looks to be 4". Worth the $50 I spent.
Been reading a LOT of posts about tire size, fit issues, backspacing, etc. and it looks like I can get away with a 235/60 or even a 245/60 tire all the way around without too many problems. Even with the short backspacing.
Do y'all think I better stay with a 235 to avoid any rubbing, or will a 245 still fit with only 4" of backspace? I'll roll the rear lip if I have to....it's the front I'm most worried about.
BFGoodrich T/A's are only $85-$89 apiece.
