what's it take to get 17x9.5 on rear of '68 - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 19th, 09, 02:33 PM Thread Starter
lip rolling?
what b.s.?
would I need to move springs inboard?
thanks in advance!
looking @ 295/45/17 mt et street radials
fast is offline
post #2 of 7 (permalink) Old Jun 19th, 09, 04:47 PM
class67's Avatar
Re: what's it take to get 17x9.5 on rear of '68
It's all in the back spacing, it will fit no problem. I have 18x9.5 on the rear of my 67 with 265/40's, no lip roll are spring re-location. The back spacing that i am using is 5.75 but you can get away with 5.5.
67 Camaro RS
class67 is offline
post #3 of 7 (permalink) Old Jun 19th, 09, 04:48 PM
class67's Avatar
I just saw that you want to run a 295, I don't think that will work...the biggest is going to be a 275 unless you want to start modifying things!
67 Camaro RS
class67 is offline
post #4 of 7 (permalink) Old Jun 19th, 09, 04:59 PM
275 fits with NO issues. I had McCreary's 285/60/15 SH on my 68 which fit OK untill you went into a hard turn,or off camber bumps... then they rubbed. A 295 is 10mm wider (about a 1/4") and that just isn't going to happen w/o some work.
68 Camaro~LSx ~all motor
post #5 of 7 (permalink) Old Jun 20th, 09, 03:58 PM Thread Starter
I was under the impression that a 5"+ b.s. was a no go (for some reason) ... I had no idea a 5.5"-5.75" would fit , I can get my fingers in between tires and inner fender with my 15x8.5" 5" b.s. convo pros (makes me nervous, haven't driven it, engine swap going on again)
btw I have mono leafs, how does the ride height compare (have multis on the f'bird)
fast is offline
post #6 of 7 (permalink) Old Jun 21st, 09, 03:28 AM
Rick
Carl Casanova ran 275/40-17's on a 9.5" rim, 5.5" BS and rolled the lip.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #7 of 7 (permalink) Old Jun 24th, 09, 01:38 PM
Yup, a 9.5 with a 5.5" and a 275/40/17 is the hot ticket. Unless your car sits severely off center, you shouldn't have to modify anything. Worse case scenario, you may have to roll your wheel lip on one side, or the other.
Jon
Driverz Inc.com
"The Custom Wheel Experts"
1-866-694-5940
68Jon is offline
