15x10 backspace 69 ? - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 25th, 09, 10:02 PM Thread Starter
Trev
madcarson's Avatar
will a 5.5" backspace work on a 69 camaro ?
I had 15x10 3.5" b/s and buddy wants to trade for 15x10 5.5 b/s but camaro is at bodyshop so I can't go trial fit as working and too far away!
69 Resto MOD
383
madcarson is offline
post #2 of 3 (permalink) Old Jun 25th, 09, 10:49 PM
6D9
Ron
Re: 15x10 backspace 69 ?
Nope...not unless you have a minitub. My 15x8's with 4.5" bs barley clear.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #3 of 3 (permalink) Old Jun 26th, 09, 06:48 AM
Steve69SS396's Avatar
When mine had stock wheel wells and stock rear end I ran 15X10's with 4-3/4" back space and 275/50 tires or 28X10" slicks. If you used these rims you might need to use spacers to keep the tires from rubbing on the inside of the wheel wells.
Here are some old pics with this set up.
Steve69SS396 is offline
