Help!!! - Team Camaro Tech
post #1 of 21 (permalink) Old Jun 26th, 09, 02:23 PM Thread Starter
Jeff
Help!!!
Help! I got my new Billet Specialties rims and can't get them bolted to the front rotors.
I first thought that maybe the front rims were machined wrong. But all the rims bolt up to the rear axles perfectly by hand seating the shanked lugs.
Is this common with cheap off shore rotors??
I even borrowed a new rotor from a local parts store and the same thing, it will not bolt up?
See how the stud is not in the middle of the bore.
Jeff
- 400 Dart Little"M", SRP 10.2:1, 4340 Scat rotating Assy, Solid Roller, AFR 210 Eliminators, Jesel shaft rockers,Super vic, Prosystems 847CFM, Tko600, 12 bolt 4:10 Eaton posi W/ Strange Hy-Tuf race axles and eliminators.
Best E.T. (11.96 @ 118.06) N/A
Classic Copper 4 Spd
jcdubs is offline
post #2 of 21 (permalink) Old Jun 26th, 09, 02:35 PM
Doug
Re: Help!!!
Jeff. I was going to mention this, but i thought maybe mine were just off a hair. I had to use antisieze to get my lug nuts on and i had to move the wheels to different holes to get it to fit at all. Mine were not as bad as yours look in the picture though. When i first tried to mount the wheels without antisieze i could have sworn i might have been striping some studs, that's how tight they were. I'm not quite sure what to tell you on yours. Try putting the wheel on the other side or a diferent set of holes, maybe that will make it good enough to get them on with some antisieze like i did mine? My rears also mounted with no problems. I doubt it's the rotors because i used good ssbc rotors. It sucks either way.
Dougs72Nova is offline
post #3 of 21 (permalink) Old Jun 26th, 09, 03:17 PM Thread Starter
Jeff
Re: Help!!!
Doug, I tried it every way there is to try, put antisieze on everything.
I just got off the phone with Billet Specialties tech line spoke to Bill, he said that it is in the rotor, probably some metric pattern.
Funny you should mention the ssbc rotors, I was just looking at them.
Jeff
jcdubs is offline
post #4 of 21 (permalink) Old Jun 26th, 09, 03:21 PM
Skip
Skeeter55's Avatar
Re: Help!!!
That sucks.... The rims look awesome.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #5 of 21 (permalink) Old Jun 26th, 09, 04:11 PM
Doug
Re: Help!!!
I don't believe him on the metric pattern deal. Like i said, i used ssbc rotors. Unless ssbc uses metric as well which makes no sense to me? I hope you get it straightened out soon, i know how it feels to get them and not even be able to see them on the car!
post #6 of 21 (permalink) Old Jun 26th, 09, 04:20 PM Thread Starter
Jeff
Re: Help!!!
Yeah it sux, If they were tight that would be fine. But the way it is now there is no way they will bolt up.
I used ton of antisieze on the stud,, on the shank of the lug, in the bore and it goes in then galls. and stops dead.
I'm not sure of the metric thing either but it is in the rotor.
Jeff
jcdubs is offline
post #7 of 21 (permalink) Old Jun 26th, 09, 04:24 PM
Doug
Re: Help!!!
This is the reason i bought the ssbc rotors kit. They ended up being the same as my parts store rotors. I agree that it has to be in the rotor because the backs fit fine, it's just odd. You will get it worked out. So, are you liking the way it looks so far with just the backs on there?
post #8 of 21 (permalink) Old Jun 26th, 09, 04:44 PM Thread Starter
Jeff
Re: Help!!!
Yeah they look sweet, But I want to see it on the ground from a distance LOL.
Jeff
jcdubs is offline
post #9 of 21 (permalink) Old Jun 26th, 09, 09:03 PM
Doug
Re: Help!!!
Jeff. Are you just going to try new rotors?
post #10 of 21 (permalink) Old Jun 26th, 09, 09:23 PM
Jeff
Re: Help!!!
Jeff
did you measure from stud to stud?
http://adaptitusa.com/index.asp?PageAction=Custom&ID=4
Are the studs press in? Are they seated all the way, or do they look bent can you put a square edge on them?
Jeff
jeff_gates is offline
post #11 of 21 (permalink) Old Jun 27th, 09, 06:13 AM Thread Starter
Jeff
Re: Help!!!
Yes
Originally Posted by jeff_gates View Post
Jeff
Jeff
Yes they were pressed in all the way and square, It appears that one stud hole in the rotor is out by about 1/16 of an inch on both front rotors.
Jeff
jcdubs is offline
post #12 of 21 (permalink) Old Jun 27th, 09, 08:06 AM
DjD
DjD's Avatar
Re: Help!!!
I would try just starting a couple threads on each stud and seeing if you can't move the wheel around a little on the studs as you put the lugs on...
...Dennis
DjD is offline
post #13 of 21 (permalink) Old Jun 27th, 09, 10:39 AM
DEREK
DEROID's Avatar
Re: Help!!!
Where did you buy the rotors from?
DEROID is offline
post #14 of 21 (permalink) Old Jun 27th, 09, 01:51 PM Thread Starter
Jeff
Re: Help!!!
OK they are on whew!!
I had to bend each stud inward ever so slightly, Took a couple tries a side going very slow.
I put a lug on the stud and moved them in with a socket and breaker bar.
They fit perfect now, easy as pie to put on. You would never know if your studs are straight until you try to put on a rim like this.
Jeff
jcdubs is offline
post #15 of 21 (permalink) Old Jun 27th, 09, 02:12 PM
Andrew
Andrew69's Avatar
Re: Help!!!
Looks really nice!
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
