wheels first or stance first - Team Camaro Tech
post #1 of 11 (permalink) Old Jun 27th, 09, 08:01 PM Thread Starter
jeff morrison
which way is more ideal- work stance to wheels , or wheels to stance??
layne02 is offline
post #2 of 11 (permalink) Old Jun 27th, 09, 08:41 PM
Rich
Re: wheels first or stance first
in my simple mind, knowing the stance/look we wanted and then matching the suspension/wheels to that plan was easiest.
Guest174 is offline
post #3 of 11 (permalink) Old Jun 27th, 09, 09:26 PM
Todd
Simple....wheels and coil overs. Then you need to make sure your driveline is set up to make it happen...
Vegas69 is offline
post #4 of 11 (permalink) Old Jun 27th, 09, 09:26 PM Thread Starter
jeff morrison
i think my question is more like this. I want to lower front and back, have the car almost level. But , if i lower without wheels and tires I am going to keep on it, ( old 14's on it now) I am afraid I may lower too much and have to adjust tires to fit . SO, should I get the tires that will be going on the car and see how much it needs to be lowered to get stance I want. Did that make sense to anyone?
layne02 is offline
post #5 of 11 (permalink) Old Jun 27th, 09, 10:14 PM
Todd
Sure, if you go to 18's then the fender lip will be 2 inches closer to the wheel lip than 14 inch wheels with the same diameter tire. You are going to need to keep around an inch of tire showing in the rear with an 18" and about the same up front.
Vegas69 is offline
post #6 of 11 (permalink) Old Jun 28th, 09, 07:07 AM Thread Starter
jeff morrison
ok, thanks guys. now I just need to make up my mind what I want
layne02 is offline
post #7 of 11 (permalink) Old Jun 28th, 09, 08:52 AM
I lowered mine, by using Z/28 front coils. The rear was already where I wanted it.
I knew the tire height and width with the 235/60/15s, and I just matched the tire and rim size that fit without rubbing for the wheels I wanted. If you want extreme tire width you will need to modify your wheel wells. but you can get a pretty fat tire and rim on a....... wait a minute what type of Camaro are you talking about.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #8 of 11 (permalink) Old Jun 28th, 09, 05:23 PM
Todd
Good point!
Vegas69 is offline
post #9 of 11 (permalink) Old Jun 28th, 09, 06:09 PM Thread Starter
jeff morrison
it's a 67 . i'm not too worried about huge width, and would really like to run same tire on front and back if i can. i had 17x8 in mind. like i said, i want stance to be pretty close to level.
layne02 is offline
post #10 of 11 (permalink) Old Jun 28th, 09, 06:54 PM
DjD
DjD's Avatar
Jeff - knowing what wheel and tire you plan to run, not exact style but size is important when you lower a car, you don't really need to have them though. Start with what you have (14" wheels and tires) and figure out how tall they are. Next figure what you would like to run and come up with how tall the new tires would be.
Use www.tirerack.com/tires/SearchTires.jsp and after entering a size pick a brand and go to spec's, you'll find everything you want to know about a tire there...
You may find the 17's you want are real close in height to what you have already. Just an example a 205/70/14 and a 235/45/17 are both 25.4" tall. If your choices match like this it's just a matter of marking the 14" tire to show where a 17" rim is in relation to the fender lip.
...Dennis
DjD is offline
post #11 of 11 (permalink) Old Jun 28th, 09, 08:19 PM Thread Starter
jeff morrison
thanks dennis, big, big help. thanks again
layne02 is offline
