wheel ? - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 2nd, 09, 06:01 PM Thread Starter
Chris
wheel ?
are any of you guys running a 10" wheel on a 68,johnny5 a couple posts down has them on his 69 and I was wondering if they would fit on a 68 also.Also what about a 10" wheel with a 28" tall tire on a 68 or am I limited to an 8" wheel,anyone got any pics,Thanks
CMQuickcoupe is offline
post #2 of 8 (permalink) Old Jul 4th, 09, 10:44 AM Thread Starter
Chris
Re: wheel ?
has nobody put a 10" wheel on a 68 with stock tubs ever?
post #3 of 8 (permalink) Old Jul 4th, 09, 02:25 PM
Re: wheel ?
10" wheel will fit... but I've only seen low profile tires on them.
https://www.camaros.net/forums/showthread.php?t=153193
https://www.camaros.net/forums/showthread.php?t=153144
https://www.camaros.net/forums/showthread.php?t=33680
68 Camaro~LSx ~all motor
post #4 of 8 (permalink) Old Jul 4th, 09, 07:55 PM
Alex Folino
Send a message via AIM to AlexFolino
Re: wheel ?
They fit but could be close depending on the tire, guy at work has 10" rims on the back of his 68
GM service technician.
25 years old. I only drive chevys. Everything else and i do mean everything can rust in piece.
68 owner-The only way to go
Camaro: A small vicious animal that eats mustangs.
AlexFolino is offline
post #5 of 8 (permalink) Old Jul 7th, 09, 07:16 PM
class67's Avatar
Re: wheel ?
Back spacing is the key to a good fit!...you might be better off with a 9.5".
What size wheel are you looking at (diameter)?
67 Camaro RS
class67 is offline
post #6 of 8 (permalink) Old Jul 7th, 09, 07:34 PM Thread Starter
Chris
Re: wheel ?
I was just wanting to put a 15x10 with a 275-60-15 mickey drag radial on it to lay the foot print out alittle more than the 8' wheel does but if the 10 wont fit I may just stick with the 8" unless I put a higher priced wheel like bogart or something to get a 9" or so on it.
post #7 of 8 (permalink) Old Jul 7th, 09, 07:38 PM
Dan
Re: wheel ?
I think you could have a problem with the 275/60. That would be a pretty tall sidewall and depending on your ride height you could have a problem.
I just ordered a new set of wheels and got 15x10's for the rear. Got a 295/50/15 MickeyThompson S/T set for the rear, but my car is mini-tubbed, so it's not a good comparison for you.
I won't have the wheels for a few weeks, but PM me in a while to see how they fit.
Dan
1968 RS - Black
408 w/ Muncie 4 speed & 12 bolt rear
Deluxe Houndstooth Interior
Dropped 2" with TeamIII Mini-Lites
Click for Picture:
funbnme is offline
post #8 of 8 (permalink) Old Jul 7th, 09, 08:02 PM Thread Starter
Chris
Re: wheel ?
I plan on running the caltrac setup with 1" drop built into the springs,I talked to them and they said the 1" drop will work with this size tire but he thought I may run into rubbing issues up inside the rear wheel wells with there 2" drop springs and this size tire but not positive.
