275/40R17's in Rear are Rubbing - Team Camaro Tech
post #1 of 18 (permalink) Old Jul 24th, 09, 09:35 AM Thread Starter
Jonny
Not sure of my current rim backspace but it's very tight on both sides of the tire.
Outside of the tires are rubbing the inside of the wheel opening molding during suspension travel (straight up and down).
Inside of the tires are rubbing the tubs during slow turns over speed bumps, driveways, etc. (axle tilt).
Anyone else have this problem? Wondering how I solve without limiting the suspension travel. My tires are getting pretty chewed up! Yikes!
The Beerboy is offline
post #2 of 18 (permalink) Old Jul 24th, 09, 09:53 AM
Skip
Skeeter55's Avatar
Re: 275/40R17's in Rear are Rubbing
Johnny what year any lowering done and do you have any pics.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 18 (permalink) Old Jul 24th, 09, 10:00 AM Thread Starter
Jonny
Hi Skeeter,
69. Yes, should have mentioned the lowering. Not sure exactly how much as it was done before I got the vehicle. I'd estimate 2" drop using drop shackles on the leaf springs. The car sits level as shown in my profile pic.
post #4 of 18 (permalink) Old Jul 24th, 09, 10:12 AM
Skip
Skeeter55's Avatar
Nice ride and puppy... I also have a 69 with 1.5 lowering leafs from Hotchkis, but i am running 285/40/18 with a stock 12-bolt and drum brakes... My rims are 18x9.5 with 5.5 back space and it also rubs very little. But we did trim the outer wheel well before paint and rolled the wheel molding. Next set of tires for me will be 275/40/18...
I would measure your back space to get a better idea, also if you have soft rear suspension may contribute to it.
post #5 of 18 (permalink) Old Jul 24th, 09, 10:17 AM
Smaller tires, possibly?
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #6 of 18 (permalink) Old Jul 24th, 09, 10:48 AM Thread Starter
Jonny
Trimming would have been the way to go before paint! It may be time break out the grinder..! I'm also running a stock 12 bolt and drum brake setup. Thx for the info.
post #7 of 18 (permalink) Old Jul 24th, 09, 10:53 AM
Skip
Skeeter55's Avatar
If you do this do NOT trim past the welds the hold the inner and outer quarters together. But take off the tire first and look at its rubbing location and only trim that area. But you can always get smaller tires to.
post #8 of 18 (permalink) Old Jul 24th, 09, 10:59 AM Thread Starter
Jonny
I need to measure out my rim width, but how much less wide can I go for tire size on the same rim?
post #9 of 18 (permalink) Old Jul 24th, 09, 11:14 AM
Skip
Skeeter55's Avatar
It all depends on the brand of tires..
post #10 of 18 (permalink) Old Jul 24th, 09, 11:53 AM
DjD
DjD's Avatar
I went with 255/45-17's after trying to fit 275/40's Nitto 555's out back. Here's the comparison;
255/45ZR17 Section Width = 10.08", Height = 25.95
275/40ZR17 Section Width = 11.02", Height = 25.59
Before disc's the 275/40's scrubbed the inner fender fairly hard but didn't touch the outer lip. The 255/45's fit well but still scrubbed the inner fender some. After installing the rear disc's I needed to trim the outer fender lip some, inner scrubbing didn't completely go away.
Every brand tire measures out a bit different...
...Dennis
DjD is offline
post #11 of 18 (permalink) Old Jul 24th, 09, 12:21 PM
Tom P's Avatar
275/40R17's w/rear lowering springs here also and mine rub on the inside slightly - since it only rubs over bumps and hard turns at drives, I live with it.
For the outside - I did break out the die grinder - just take a little at a time, sand the edge smooth and take your time. I am guessing you only need 1/4" or less. If you feather it out, its virtually not visible.
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #12 of 18 (permalink) Old Jul 25th, 09, 10:56 PM
Please consider coil over, over load shock helper springs to keep her from dropping down and cutting your tires!
I know all about this crap, me w/ my '67 and L-60/14's that actually measure a modern 298/53-14 on a 14" x 9" rim w/ 3.5" BS.
pdq67
post #13 of 18 (permalink) Old Jul 26th, 09, 07:56 AM
67 Camaros Rock
Joe Harrison's Avatar
The lowering "shackels" could be an issue. THe spring is going to tilt more and cause rubbing. YOu could try stock shackels or go global west with delrin bushings to keep them a little firmer and use a lowering block. You can always try stock shackels also. I would try this before cutting on her.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #14 of 18 (permalink) Old Jul 27th, 09, 09:48 AM Thread Starter
Jonny
Thanks for the great suggestions everyone...! I have a set of stock shackels - I'll give these a try first. Then will break out the die grinder as required on the outside. We'll see how that makes out!
Also, has anyone modified the bump stops to limit travel? I've been running this setup for 4 years now with minimal rubbing, but when I load her up with people and stuff, I get serious rubbing.
post #15 of 18 (permalink) Old Jul 27th, 09, 12:34 PM
Dr. Feelgood
Show's you these cars are not created equal...normally,a 275/40 rear should be very safe on a 9.5" wide wheel with 5.5" backspacing.I run a 285/40 on this combination w/o issues.
Just for giggles,my car swallowed up a 18x10 rear w/305/35 drag radials I mounted on it this wknd and ate it whole...no fitment issues inside or out.
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
