16' Wheel and Tire Combinations - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 26th, 09, 08:03 AM Thread Starter
Bill
Bill Bergen's Avatar
I have 16'' x 8 1/2" wheels for my 67 Camaro Convertible and am having some remorse. Seems that with this wheel I cannot find a tire that will fill the rear wheel well and not rub on the front. I put 225/55/16 on the front and it rubs on the fender well badly. I have the same on the back and it looks pretty good, although it could be a bit larger.
I am wondering if anyone has found a good combination for the front. I am considering a 215/55/60 or 205/55/16 for the front. Since the wheel is a 8 1/2" wide spec I don't know if the tire will look good on the rim. I think these tires call for a 7" rim. I think that the 215 will fit the rim better, but I am worried that it will rub the front wheel well. I have the Hotchkis 2" lowering springs on the front. BF Goodrich is working with me on this. They are very helpful and I don't want to waste their goodwill.
Any thoughts?
67 RS Convertible Camaro Restification completed August 2009. All original with updated drivetrain -Marina Blue exterior 327 with Proflo2 EFI Tremec 5 speed. Paint and Body by Lanzinis Bodyworks of Huntington Beach. Great fun!
Bill Bergen is offline
post #2 of 5 (permalink) Old Jul 26th, 09, 08:22 AM
Re: 16' Wheel and Tire Combinations
What is the backspace or offset on your wheels?
I'm afraid that if a 225 tire rubs, you do not have a compatible offset
post #3 of 5 (permalink) Old Jul 26th, 09, 08:48 AM
DjD
DjD's Avatar
I think your problem on the front is the 8.5" wide wheel and it's backspacing. You should be able to run a 235 on a 7" wheel with 4" back spacing or a 245 on a 8" wheel with 4.75" back spacing.
225/55-16 = 25.7" tall and 9.1" section width
245/55-16 = 25.6" tall and 9.8" section width
225/60-16 = 26.6" tall and 8.9" section width
Compare those sizes to (the most common size to fit the front of a 1st gen) a 235/60-15 @ 26.1" tall and 9.5" section width and with the right wheel and backspacing you shouldn't have a problem finding a front tire...
...Dennis
DjD is offline
post #4 of 5 (permalink) Old Nov 22nd, 09, 08:01 AM Thread Starter
Bill
Thanks, DJD for your reply. I will double check the camber for my car. I just got it aligned and gave them a .5degree to one degree spec, but you never know. I did put button bolts in the wheel housings, that helped quite a bit. I do need to raise my car a bit regardless, because my headers drag just getting out of the driveway! They are Hooker competition headers.
As for a supplier, I did find that Classic Industries carries a spring shim that was used by the factory to correct ride height. It fits on the lower part of the spring perfectly and provides about an inch of hight. They also have a thin isolator pad that goes in the top of the spring. This took care of my plight.
Thansk again for the advice.....
post #5 of 5 (permalink) Old Nov 22nd, 09, 01:43 PM
Kip
+1 on it being a backspacing issue. I used to run 16x8 wheels with 225x55x16 on the front and 255x50x16 on the back.... no rubbing...
4.25 or 4.5 backspacing (cant remember which)
Car was lowered in front and had GS mod...
I really like 16 in wheels on first gen Camaros... just is a pain to find tires....
kv67ssrs is offline
