Squeeling Tires - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 30th, 09, 04:15 PM Thread Starter
Rich
Squeeling Tires
i have 17X8 TT2s with energy suspension bushings all around, stock front control arms and sway bar with OER front springs. Edelbrock shocks
the rear i have the same 17x8's with 5 leaf springs, edelbrock shocks and energy suspension bushings.
When i get above ~20 mph (my speedo is WAY off) my wheels start to screech and squeal when i go around turns. I had the control arms shimed by the shop. Next is the tie rods (tie rod broke so the shop couldn't do it at the same time as the upper control arm shim, i've replaced it since then but haven't gone back to have them adjusted.
Could anything else be the culprit?
1968 Camaro; 350/th-400
VintageAgain is offline
post #2 of 2 (permalink) Old Jul 30th, 09, 04:40 PM
Re: Squeeling Tires
rebuild/replace all front end bushings/tie-rod ends/ball joints/Ect that hasn't been done yet and get a front end alignment.
68 Camaro~LSx ~all motor
