Torque Thrust 2 fitment - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 7th, 09, 11:50 AM Thread Starter
Todd
I am looking at some 15 X 8 polished Torque Thrust 2 wheels on Craigslist for $100 each (only has 3 wheels) new in the box, but I am not sure they will fit my 68 Coupe.
My car has a stock suspension and the part # of the wheels is 505-5861 which is a 15 X 8, 5 X 4 3/4 bolt pattern with a 3 3/4 inch back space.
I want to make sure these fit before I purchase them..
Anyone have this set up?
camarotoddd is offline
post #2 of 4 (permalink) Old Aug 7th, 09, 11:55 AM
Re: Torque Thrust 2 fitment
I had them on the rear with a 1/4 inch spacer BUT am running a 9" that is about 2 inches narrower than a 10 or 12 bolt. I'd say youd want 4.5" of backspace with an 8" rim front and back. So if your car is stock, no they won't work unless you wnat them to stick out past the fenders.
69 Coupe: Forged Hydraulic Roller 383, Holley HP 750 DP, AFR195s, RPM Air Gap, Borg Warner T-56, Hooker Super Comp 1.75", Ford 9" with custom Moser axels, 3.89 Posi, MSD digital 6, Hotchkis springs, 4WDB, [email protected] on bald Nitto 555's
johnny5 is offline
post #3 of 4 (permalink) Old Aug 7th, 09, 04:04 PM
Matt
I have the 4.5" backspace TTII's on front and back, 15x8. They fit fine with 235/60/15 and 255/60/15.
These are very aggressive. They will have the tires sticking out of the fenders.
Great price though, if you like that look.
_____________________________________________
1968 Teal Blue Metallic/Blue interior
327/210, 4-Speed Saginaw
Orig., #'s match engine, trans., driveline: 2nd owner
'68LL327 is offline
post #4 of 4 (permalink) Old Aug 8th, 09, 07:28 AM
joseph l clance
joe clance's Avatar
not enough backspacing
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
