275/60R15 M/T Drag Radial on 7's? - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 4th, 09, 09:41 AM Thread Starter
Jeremy
Question 275/60R15 M/T Drag Radial on 7's?
I really need some drag radials for my 69. the only problem I have is I have 7 in with 3.5" b/s Centerline Auto Drags... I can't afford to buy the wheels also...since I had to fork out quite a few bucks for the new trans... I have run these size tires on Weld Draglites years back, because I was poor and that is all I had... Now they didn't rub when I had noone in back, but when I had people in the back, they would rub slightly, on the outside lip of the quarter panel.. but I don't haul people in back anymore... so I don't know if I can get away with these tires, or I have to run the 255's? It would be nice to have the taller tire with my 3.90's and the 3.06 ratio of the 1st gear on the 700..
69 Camaro Finally restored. New 496, 700R4, 3200 stall, 3.90 12 bolt posi
LYK2ROC is offline
post #2 of 8 (permalink) Old Oct 4th, 09, 11:16 PM
6D9
Ron
Re: 275/60R15 M/T Drag Radial on 7's?
It will be fine. I have seen 275/60/15's on 7's a bunch of times and it worked just fine. There approved sizes are 7.5-9.5. The extra 1/2" narrower is nothing.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #3 of 8 (permalink) Old Oct 5th, 09, 07:13 AM Thread Starter
Jeremy
Thanks Ron.. I'll order them this week.
LYK2ROC is offline
post #4 of 8 (permalink) Old Oct 5th, 09, 03:26 PM
6D9
Ron
Good deal!
69 Camaro
TH400/GV OD
9" 3.50
6D9 is offline
post #5 of 8 (permalink) Old Oct 5th, 09, 03:35 PM
Chris
When I first bought my car, I had the same size tire on a 6 inch rim. It worked, but not right. I have a 8 inch rim now. 7 will be fine.
hirpms is offline
post #6 of 8 (permalink) Old Oct 6th, 09, 04:54 AM
I had them on 7" Pro Stars when I had my nova. They will be OK.!!!
Camaro Mark is offline
post #7 of 8 (permalink) Old Oct 6th, 09, 06:20 AM Thread Starter
Jeremy
Thanks guys. I appreciate all the help. How much air can I safely run these at the track. The problem with the 1/8 mile track I will be running at is a circle asphault track, and traction is going to be a problem. Especially with the 3.06 first gear and 3.90's and a roller BBC!
LYK2ROC is offline
post #8 of 8 (permalink) Old Oct 6th, 09, 01:32 PM
6D9
Ron
Mine seem to work best with 16-18 psi.
69 Camaro
TH400/GV OD
9" 3.50
6D9 is offline
