Widest wheels I can fit on my 67 - Team Camaro Tech
post #1 of 17 (permalink) Old Nov 12th, 09, 12:37 AM Thread Starter
frank
i have a 67 camaro and i plan to put some 17" american racing torq thrust wheels on it...what's the widest wheel and tire combo i can put for the front and rear??? i heard i can get a 17x8 with 5" backspacing on a 275 tire on the rear....is that correct or can i go wider??? don't plan on cutting or modifying the stock wheel wells...and as for the front...whats the widest wheel/tire i can use and...what backspacing??? using 2" drop spindles in front with stock height springs and hotchkis 1.5" drop rear leaf springs...any suggestions, help or pix would be most appreciated!
fjas67 is offline
post #2 of 17 (permalink) Old Nov 14th, 09, 08:11 PM
class67's Avatar
Re: widest wheels i can fit on my 67
you can run an 8" wide wheel on the front with a 4.875" or 5" backspace and a 9" or 9.5 on the back with 5.25" and 5.5" to 5.75" respectively, on the rear.
67 Camaro RS
class67 is offline
post #3 of 17 (permalink) Old Nov 14th, 09, 09:35 PM
BARRY
9.5 on rear 275/40 /17 5.5 bs 17/8 245/40/17 5inch bs on front and . i do have discs on rear
Barry
[IMG][/IMG]
[IMG][/IMG]
pro tc is offline
post #4 of 17 (permalink) Old Nov 23rd, 09, 04:13 PM Thread Starter
frank
thanks a lot guys...i really like the setup you got on that 67 barry!!! beautiful car!!! i think i'll get the same setup but i think im gonna go with american racing torq thrusts or the new rocket racing fuel polished wheels!!! but thanks for the wheel specs!
fjas67 is offline
post #5 of 17 (permalink) Old Nov 24th, 09, 07:39 AM Thread Starter
frank
Re: Widest wheels I can fit on my 67
hey barry i was just wondering if your 67 is lowered or if that's the stock ride height...well...looks amazing!!!!! did you have to modify anything in order to the the wheels you those to fit??? or is everything in the stock location???
fjas67 is offline
post #6 of 17 (permalink) Old Nov 24th, 09, 03:49 PM
Really nice looking ride
UNEZRYDR is offline
post #7 of 17 (permalink) Old Nov 24th, 09, 08:48 PM
BARRY
ya car is lowered. one inch guldstrand lowering block in rear eibach front springs.
Barry
pro tc is offline
post #8 of 17 (permalink) Old Nov 24th, 09, 09:02 PM
Terry
Send a message via Yahoo to adkin161
Barry
[IMG][/IMG]
[IMG][/IMG]
Does it matter if you have disc brakes or drums?
adkin161 is offline
post #9 of 17 (permalink) Old Nov 25th, 09, 05:32 AM
Frank
No matter disc or drums. Same track width.
ProdigyCustoms is offline
post #10 of 17 (permalink) Old Nov 25th, 09, 07:31 AM Thread Starter
frank
hey barry, one last question...do the wheels ever rub on hard cornering or turns?
fjas67 is offline
post #11 of 17 (permalink) Old Nov 25th, 09, 07:54 AM
Matt
I run 18x9 with 5.25 BS/275x40 in the back. Had to use 1/4 inch spacer as I was getting a slight rub on the inner fender well. Spacer did the trick. I agree 9.5 wheels will work as well as the 275 tire is still wider than the wheel. Fronts seem to be the more troublesome. It appears problems tend to start for some at with 245 tires. Do some searching and you will find that half the guys running 245 up front have no rubbing issues while the other half do. I went with 18x7 wheel and 4.25 BS/225x45 tire just to be safe. If you want the 8 inch wheel, I would recommend the 235 tire. See this threads (if you haven't already) for some good info:
https://www.camaros.net/forums/showthread.php?t=163785
https://www.camaros.net/forums/showthread.php?t=160013
https://www.camaros.net/forums/showthread.php?t=163345
Matt
zlek131 is offline
post #12 of 17 (permalink) Old Nov 25th, 09, 03:42 PM
BARRY
no rub at all. when i had drums in the rear i had to use a 1/4 spacer but when i went to discs i didnt need the spacer anymore. i have the solid alum bushing in front eye of the leif spring and polys in the rear eye
Barry
pro tc is offline
post #13 of 17 (permalink) Old Nov 26th, 09, 09:37 AM
Kevin
While everyone wants the widest tires possible we must be careful since all cars are different. How much the car is lowered. Frames can be bent, rear ends not centered, and panels installed incorrectly. A 275 on a 9" wheel is not that much bigger then a 255 on a 9" wheel, 3/4" or less. Trust me with street tires your ability to hook up will not change. If you spin a 255 you will spin a 275! You really need to measure your own car for the correct fit. I went with 255 50 17 @ 27" dia more so to fill the wheel opening. I have zero rubbing issues and mine is lowered 3".
Name:	Drivers side view.jpg
ID:	13026   Click image for larger version
Name:	Slide a Links.jpg
67 Viper Blue with White Z28 Stripes 540CI 675HP 690FT LBS 200R4 9" 3.70
67Kevin is offline
post #14 of 17 (permalink) Old Dec 15th, 09, 11:39 AM Thread Starter
frank
hey kevin..i was wondering how wide of a wheel and what backspacing you were running with those 255's in the rear
fjas67 is offline
post #15 of 17 (permalink) Old Jan 19th, 10, 09:07 AM Thread Starter
frank
thinking of going with 18's in the rear!!! could i still run a 9.5" wide wheel with the same backspacing as the 17's or does that all change??? i got sold this weekend at pomona...some guy has a 67 camaro rs dumped on 18's in front and 20's in the rear...now i'm not a fan of muscle cars on huge rims but this car looked amazing....coulda been the air bags in front totally slamming the car to the ground but...who knows...anyways i've decided to go with 17's in front and 18's in the rear
fjas67 is offline
