Help! What would fit with my setup! - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 18th, 09, 12:37 PM Thread Starter
I decided to go with the Hotchkis TVS, 1.5" drop on the rear with 2" drop in the front with some Wilwoods. I have a 1967 RS, and I decided I want to go with either 1 of these 2 wheel combos. No tubs.
F18x8 R18x9
or
F18x8 R19x10 (R19x8 or maybe R20x8.5)
I want to have 40 front Aspect Ratio and 35 for the back. Would either of these combos fit without rubbing?
Thanks!
agent784 is offline
post #2 of 2 (permalink) Old Nov 18th, 09, 02:07 PM
class67's Avatar
Re: Help! What would fit with my setup!
Both combos would work, you want an 18x8 up front with a 4.875 backspacing and a 245/40 and in the rear an 18x9 with a 5.25 backspacing with a 275/40 or a 19x8 with a 275 as well, i think will work for you. I would (personally) stay away from the 20" wheel and if you decide to go with a 10" wide rear wheel you want to make sure your backspacing is "dead on" as it will be a very tight squeeze. Good luck!
67 Camaro RS
class67 is offline
