Largest tire on tubbed 67 camaro fitment? - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 15th, 09, 05:45 AM Thread Starter
My camaro is tubbed in the back, but not a full blown pro street tub. I have run a 325/50/15 back there before and still have 2" to the inner frame rail. I see alot of camaros at the drag strip and in magazines running a much bigger/taller tire then the 325. In Popular Hot Rodding I believe, Ernie Gonzales's 67 is running a 315/60/15 that barley fits in the wheel well opening.
My questions is: How tall of a tire can you safely fit in a stock wheel well opening? How much room do you need from the bottom front and back of the wheel well openings? I am not concerned about width, I have the room. I just feel like I should be able fit a taller tire then 28"s in there. I recall a camaro here at National Trails in Columbus running a 295/60 MT which I believe is 29" tall.
What are the drag racers running? Here is a link to pics of his ride.
http://www.popularhotrodding.com/fea...aro/trunk.html
Thanks, Erik
67 Camaro Pro Street, 540 Bill Mitchell Merlin big block, Merlin Aluminum heads, Holley 870, hydraulic camshaft, 2" Hooker Super Comp headers, Mallory and Crane ignition system, TH400, 2600 stahl, Ford 9" w/ 4:10 gears and posi.
Erik Beckett is offline
post #2 of 2 (permalink) Old Dec 15th, 09, 06:21 AM
Re: Largest tire on tubbed 67 camaro fitment?
I have 13.50 X 28 Et Streets on now with no problem. I used to run 11.50 X 28.5 Firestone slicks, a couple of times they rubbed on the front lower wheel well lip.
fiveforty is offline
