69 RS- Fitting 17" wheels/tires... - Team Camaro Tech
post #1 of 15 (permalink) Old Jan 2nd, 10, 12:21 PM Thread Starter
Andy
I would like to run 17" ralley wheels on my 69 RS convertible, and have done a bunch of research and it looks like 17x8's in the front, and 17x9's or 9.5's in the rear are the setup. It also looks like 4.5 BS in the front and 5.5 BS in the rear is the way to go too, does this sound good? Also, who makes the 17" Billet Ralleys these days? I know Wheel Vintiques made them at one time, but have only found 18" Billet ones on their website.
The one thing I couldn't find with the research I have done on this site so far is what folks have done to fit certain size tires/wheels. I don't really want to mod my wheel openings or suspension at all, so what size tire can I get away with?
My car sits fairly high right now, but I do plan on doing some suspension mods to it as well. Nothing radical, just want to lower it an inch or two all the way around. It has big block springs in the front, with a SB motor.... BB springs gotta go...
Andy in Pa. is offline
post #2 of 15 (permalink) Old Jan 2nd, 10, 12:37 PM
Steiner
Re: 69 RS- Fitting 17" wheels/tires...
Not rally rims, but fitment info is here based on what most other people are doing with a 17" rim. No modifications necessary.
https://www.camaros.net/forums/showthread.php?t=152694
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 15 (permalink) Old Jan 2nd, 10, 12:50 PM Thread Starter
Andy
More good info, thanks!!
A.
post #4 of 15 (permalink) Old Jan 13th, 10, 10:25 PM
class67's Avatar
with an 8" wheel in front you want 4.875 backspacing and with the 9" rear, you want to go with 5.25 or 9.5" rear, go with 5.5 to 5.75 (depending on how low you want to go!)
67 Camaro RS
class67 is offline
post #5 of 15 (permalink) Old Jan 14th, 10, 07:31 AM
Skip
Skeeter55's Avatar
Wheelvintiques has them in 17" chrome or steel, heres a link.
http://wheelvintiques.myshopify.com/...llye-68-series
These are 18" Billet Ralleys.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #6 of 15 (permalink) Old Jan 14th, 10, 10:39 AM
JcGc's Avatar
Skip,
There you go again....showing off your car. You make those of us that are not even close to being done beat our heads in the wall... Common income tax money!!!
1969 Camaro
JcGc is offline
post #7 of 15 (permalink) Old Jan 14th, 10, 12:31 PM
Dr. Feelgood
4.5" b/s on an 8" front wheel really isn't enough,that'll put you too close to the outer fender.A better b/s would be 4.75-4.875" as was noted but you'll need to find a wheel company that offers those custom b/spacing.Vintage Wheel Works is a perfect match for period-correct looking wheels with the right backspacing for these cars.
For the rears,a 9.5" wheel w/5.5" b/s is a common setup,I'd recommend a 245/45 front and a 275/40 rear to make sure they tuck in nicely.
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
post #8 of 15 (permalink) Old Jan 14th, 10, 01:33 PM Thread Starter
Andy
I REALLY like that look on Camaros... but Wheel Vintiques prices are
I may end up settling for a Torque Thrust-style wheel instead, unless there is someone else doing 17" rallys more affordably.
post #9 of 15 (permalink) Old Jan 14th, 10, 02:00 PM Thread Starter
Andy
Thanks, good to know that 4.5" BS in the front may not be enough. I would like to fit a 275 on the rear, I'll have to give that a shot.
A.
post #10 of 15 (permalink) Old Jan 14th, 10, 03:34 PM
Dr. Feelgood
A.
I've been known to have several sets of wheels on my cars...ask away if you have any questions.
I've run a 285/40 rear on a 17x9.5 wheel (5.5" b/s) and mostly cleared the inner fenders w/o issue until I ran 1/4" spacers and then no problems.A 275 tire should be just right.
post #11 of 15 (permalink) Old Jan 14th, 10, 04:21 PM Thread Starter
Andy
So I won't have any troubles with 275-40-17's rubbing on big bumps or anything (assuming I use a 5.5 BS wheel of course)? My plans are to do the Hotchkis 1.5" lowering springs in the rear too (front is getting the 2" drop coils). I have no problem running a 255-45-17 in the rear, but if a bigger one fits, thats even better.
When I first got this Camaro, EVERY tire rubbed on the fender/frame somewhere... It was a shame because each tire was so badly scraped/scarred that they were basically junk.... with 95% of the tread still on them!!!
post #12 of 15 (permalink) Old Jan 14th, 10, 08:37 PM
Dr. Feelgood
Everyone of these cars is a little bit different so what absolutely works on one may not on another but that setup we discussed with a 275/40 tire is pretty safe and does fill up the wheelwell nicely.
post #13 of 15 (permalink) Old Jan 15th, 10, 07:06 AM
Skip
Skeeter55's Avatar
Everyone of these cars is a little bit different so what absolutely works on one may not on another but that setup we discussed with a 275/40 tire is pretty safe and does fill up the wheel well nicely.
X2 My 285/40/18 tire and 9.5 rim with 5.5 back space rub just a little on the inside of the of the wheel well, but doesn't rub with trimming on the outer lip.
post #14 of 15 (permalink) Old Jan 15th, 10, 07:26 AM
A.
I tried a 17x8" 4.5 BS with a 245-45-17 tire on the front with Hotchkis front springs and it's too close for comfort. I went to an 18x8" 4.75 BS with a 245-40-18 tire and it fits perfect.
For the rear, the 17x9.5" 5.5 BS 'usually' works, but you've got a measure your specific car. If you've got any side-to-side variance with the differential being off-center and you may get some rubbing.
Neil B is offline
post #15 of 15 (permalink) Old Jan 15th, 10, 08:59 AM
Dr. Feelgood
My rear tires on my 17" VWW wheels are also 285/40's and I have the same issue as you,very slight inside rubbing only on odd,steep driveway entrances and culverts.
Strange thing about my car is I have TONS of room outside (fenders have been rolled nicely) so I run a thin 1/4" spacer and that solves the problem.
My 18" setup features a 10" wide wheel with 275/40 rubber and I could easily run a 285 no problem.
Each one of these cars is truly different...
