Drag Radial Handling - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 9th, 10, 06:55 PM Thread Starter
How do drag radials handle on the road - beyond going straight - like in twisties? Better, worse, same as regular radials? Not slicks but DOT approved ones.
69 Pace Car and 69 Hard top
srode is offline
post #2 of 6 (permalink) Old Jan 9th, 10, 07:08 PM
Steve69SS396's Avatar
Re: Drag Radial Handling
Only difference I noticed was better straight line traction with the drag radials compared to regular radials. My car has no sway bars, a spool and 3-1/2" rims on the front, so I don't push it hard through the corners. Somebody else can probably comment on their cornering ability.
Steve69SS396 is offline
post #3 of 6 (permalink) Old Jan 9th, 10, 07:11 PM Thread Starter
I was thinking all 4 corners - so they match
srode is offline
post #4 of 6 (permalink) Old Jan 9th, 10, 07:19 PM
Dan
I've tried the BFG's and MH (rear only on either), the BFG's actually don't handle too bad as long as the air pressure is kept at street levels. The M&H's are washy in the corners but the wrinkle much better and launch better than the BFG's. There are a lot better soft compound tires available for all 4 corner use- Nitto RII's and NT01's are very good, (RII's have a real tread at least), Toyo and Kuhmo make some soft compound tires too. A lot of these a good 1/2 way point between street tires and full on slicks for road course duty.
The problem I would see with drag radials in the front is the soft sidewall, the car could wander, be washy, or turn-in poorly. Also you'll likely never get them warm enough on the street to get any added traction.
62 Corvette (Stock Restoration)
68 RS/SS Camaro, LS7/T56
68 RS Convertible project LS3/480/4L70
2006 Corvette Z06
2011 Corvette GS Convertible
68sixspeed is offline
post #5 of 6 (permalink) Old Jan 10th, 10, 03:53 AM Thread Starter
Thanks, I'll take a look at those.
srode is offline
post #6 of 6 (permalink) Old Jan 10th, 10, 05:26 AM
I have no issues with them but I also don't take corners hard (ProTouring style) buy did dive like a regular car.
Since adding the spool I'm easier in the corners.
I would pay close attention to the wide painted stripes at cross walks LOL
Also they don't ware as long as regular radials (tread ware rating 0 )
68 Camaro~LSx ~all motor
