Heavy Ralley Wheels - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 12th, 10, 05:34 PM Thread Starter
Chris
Heavy Ralley Wheels
Just went to a set of American racing TTDs. I sold my ralleys on e-bay.
I didn't think they were that heavy. Shipped them UPS. The rear 15x8s weighed 30lbs and the fronts weighed 25lbs. With centers and rings.
I will be saving about 55lbs. I don't have to go on a diet after all.
hirpms is offline
post #2 of 10 (permalink) Old Jan 13th, 10, 10:19 AM Thread Starter
Chris
Re: Heavy Ralley Wheels
44 lbs Exactly. 55 was a little high.
hirpms is offline
post #3 of 10 (permalink) Old Jan 13th, 10, 01:42 PM
Sean
That's exactly why I'm planning on ditching the old rallys, love the look but they weigh a ton. I wonder how much I'd save from a set of draglites or the new Billet specialties drag wheel. Those TT's are not exactly light weight.
Nice, you can go out and have a triple cheese burger to celebrate..
Sean
Franklin D. Roosevelt
68rs406 is offline
post #4 of 10 (permalink) Old Jan 15th, 10, 11:57 AM Thread Starter
Chris
Its like taking off those work boots and puttin on the tennis shoes.
hirpms is offline
post #5 of 10 (permalink) Old Jan 16th, 10, 01:17 PM
Dante'
Build enough horsepower and it won't matter.
69 Camaro SS
windycity1 is offline
post #6 of 10 (permalink) Old Jan 16th, 10, 04:47 PM
If you removed the Ralleys @ 55 lbs....what do the new wheels weigh ????
Saved maybe 20 lbs. ???? But every bit helps
68 Camaro~LSx ~all motor
post #7 of 10 (permalink) Old Jan 16th, 10, 06:17 PM Thread Starter
Chris
The Ralleys weighed 110lbs all four. The TTDS weigh 66.
hirpms is offline
post #8 of 10 (permalink) Old Jan 16th, 10, 06:29 PM
OK...make sence now What was I thinkin'
post #9 of 10 (permalink) Old Jan 16th, 10, 07:28 PM
Jeremiah
If it were a drag car this would be a huge gain..
I have always been told for every 100 lbs of weight you remove from your car your 1/4 mile times can improve by as much as one tenth of a second. Every 1lb of rotational weight is good for 4lbs of static weight depending on the weight of the wheel X the force of the launch/acceleration.
Another thing to consider is even though you lost weight overall you gained diameter and more weight is concentrated at the outer diameter than before. In other words you likely gained rotational mass by changing to a larger diameter wheel/tire combo. It will take more power to turn the wheel/tire combo than a smaller diameter wheel/tire combo of the same weight.
Its a give/take situation.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #10 of 10 (permalink) Old Jan 18th, 10, 11:00 AM Thread Starter
Chris
I stayed with 15in wheels.
hirpms is offline
