67 rally wheel size?? - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 18th, 10, 05:18 PM Thread Starter
I am looking to buy a new set of rally wheels whats on my mind is fronts 15x7-4.5 bs 215 65r15, rears 15x8-4.5 bs 255 60r 15. Will I have a rubbing problem or can I go with something a little larger? The suspension is all stock-sbc. The tires I would like would be the BF Goodrich radial TA's. Any pictures of this setup out there?
ML67
post #2 of 7 (permalink) Old Jan 26th, 10, 04:42 PM Thread Starter
Re: 67 rally wheel size??
No replies, come on guys help out.
ML67
post #3 of 7 (permalink) Old Jan 27th, 10, 05:55 AM
Mitchell
I don't see any issues. That is a common setup and your sizes are good!! You should be happy!!
Newstalgia Wheel is offline
post #4 of 7 (permalink) Old Jan 29th, 10, 02:23 AM Thread Starter
Thanks mitchell
ML67
post #5 of 7 (permalink) Old Jan 29th, 10, 08:34 AM
Jeremy
I have 15x7 front and rear with 4.5 backspacing and 235 front and 255 rear. The front will rub a little bit at full lock with drums on front. 4.5 backspacing tucks the wheels in a little further if you have drum brakes. 4.5 is perfect for disc brakes, probably no rubbing with the 235 on front. I haven`t tried it yet, but hopefully will soon.
67 Camaro
makoshark is offline
post #6 of 7 (permalink) Old Jan 29th, 10, 09:27 AM
Bill
Send a message via Yahoo to IDS_Bill
I have 15x7's and Wide Oval tires and I have a slight rubbing problem when I crank the wheel to the right. Very slight but noticeable.
67 Yenko Tribute - 427/4SPD/Bolero Red
2010 2SS/RS Camaro - Victory Red with White Rally Stripes
IDS_Bill is offline
post #7 of 7 (permalink) Old Feb 8th, 10, 04:06 PM
Steve A.
flat350's Avatar
Send a message via AIM to flat350
Have the same wheels on a 68 w/215-60-15 front and 245-60-15 rear and have no rubbing issues, the front is even lowered @ 1 1/2".
68 work in progress , but I can drive it now - O5D build - 712 trim - 02 color
Think it was a 396 , 4 spd. - now in primer , 350 , 4 spd. , lots of new body and mech. parts
flat350 is offline
