1968 camaro (need help on wheels) sizing, tires etc. - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 5th, 10, 09:45 PM Thread Starter
Doug
hey,
Im looking at getting the coy c-5s or the coy c57s. (for my 68 camaro)
and my questions are:
I would like to run a 18x9.5 in the rear but would this require shortening my rear axle? or anything of that sort? or any large modifications to the front or rear suspension
and what is a good size to run in the front? a 18x7?
and also what kind of backspacing should i use?
and suggestions on tire sizes?
i want a good stance on the vehicle.. the pro touring type.. every day driveable and long distances.
(also they will be going over the new 4 wheel disc brake convo kit i just got in)
thanks for your help...
sok68camaro is offline
post #2 of 4 (permalink) Old Feb 5th, 10, 09:53 PM
class67's Avatar
Re: 1968 camaro (need help on wheels) sizing, tires etc.
Doug, welcome to Team Camaro....you can fit an 8" wheel on the front with a 4.875 backspace and on the back you can fit a 9.5" without any rear end modification but you will need at least a 5.5" backspace. As far as tires, you can run a 235 or 245/40 up front and a 275/40 in the rear without any hassles.
67 Camaro RS
class67 is offline
post #3 of 4 (permalink) Old Feb 9th, 10, 08:28 PM Thread Starter
Doug
thank u very much for the help
post #4 of 4 (permalink) Old Feb 10th, 10, 04:34 AM
Here are measurments and pics... may find what you're looking for ???
https://www.camaros.net/forums/showthread.php?t=153193
68 Camaro~LSx ~all motor
