67 camaro front wheel backspace ? - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 23rd, 10, 04:27 AM Thread Starter
Darren
hello,
I have 235/60/15 T/A radials for the front of my 67 camaro with the front end lowered (springs) 2" Can I use a 15x7 with 4" backspace. I see alot post on here saying 4.25 to 4.5. I already have these wheels and would like to go with them but, if they will set out to far or rub I will buy others.
thanks
Darren Wilton
redhot is offline
post #2 of 3 (permalink) Old Feb 23rd, 10, 07:42 AM
Matt
Re: 67 camaro front wheel backspace ?
I run 18x7 with 4.25 BS. I also have 225/45 tires. The top outside of tire is pretty close to the fender lip. In theory, with your wider tire (235) and less back spacing (4.0), your tire will be even closer to fender lip and may cause some rubbing issues. How much closer? 235-225=10mm or 5mm (.20") on each side plus .25" due to less back space (4.25-4.0) so you are looking at 0.45" which could make a difference.
Matt
zlek131 is offline
post #3 of 3 (permalink) Old Feb 23rd, 10, 08:36 AM Thread Starter
Darren
thanks for the reply matt. I will probablly bite the bullet and get (2) 4.5 and if thats to much I will use a 1/4 spacer
thanks
Darren Wilton
redhot is offline
