How big, how wide - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 23rd, 10, 10:56 AM Thread Starter
dominick
How big, how wide
Hey I have a 69 camaro all stock 12 bolt rear What is the widest rim & tire that will fit with no problems? Spikee
spikee is offline
post #2 of 4 (permalink) Old Feb 23rd, 10, 11:39 AM
Steve69SS396's Avatar
Re: how big how wide
Read this thread. https://www.camaros.net/forums/showthread.php?t=164572
Steve69SS396 is offline
post #3 of 4 (permalink) Old Feb 23rd, 10, 12:15 PM
BILL
SPARKY69's Avatar
yup, the above is good thread!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #4 of 4 (permalink) Old Feb 24th, 10, 06:27 AM
Eric
Re: How big, how wide
Also check out the post your wheel and tire specs with a picture thread in the wheel and tire section.Good stuff there!
69 SS396 fathom green N/A525 833chrysler 4spd 3550# stock suspension 10.11/137mph
vonzipper396 is offline
