How wide can I go? 68 stock & TT II's - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 14th, 10, 08:45 PM Thread Starter
Jeff
Stock 68 setup, wondering how wide I can go with rims and tires. Don't want any issues with rubbing, but like wide tires. Looking at Torq Thrust II's in the 17 or 18" size.
-shoe
Current Projects - See my albums
68 Coupe Restomod (7-2010 to ???)
67 RS/SS Convertible project (8-2007 to ???)
Old
67 SS 396 Coupe (sold 7-12), 68 SS 350 (sold 2-12), 68 383 stroker (sold 10-09), 68 SS 350 TPI (sold 2006), 69 SS 350 (sold 1987), 68 327 (1980 Bench seat column shift), 89 RS (son totaled), 88 IROC (son totaled), 76 LT1 (roommate wrecked)
shoe is offline
post #2 of 9 (permalink) Old Mar 15th, 10, 10:31 PM
Re: How wide can I go? 68 stock & TT II's
17 or 18x8 in the front and a 17 or 18x9.5 in the rear. Tire sizes would be a 245/45/17 or 245/40/18 in the front and a 275/40/17 or 275/40/18 in the rear. I prefer the way a 275 looks on a 9.
Justin Butler
1-866-694-5940
post #3 of 9 (permalink) Old Mar 16th, 10, 08:29 AM
Matt
9" or 9.5" with 275 on rear should be good. I run 18x9 with 275's. Had a minor rub against inner well but .25" spacer did the trick. Fronts can be tricky and very just a bit from car to car as they are all a little different depending on the setup. Some will have no issues with 18/17x8 and 245 but others will. 235's seem to be the happy in between. I run 18x7 with 225's with the guarantee of no rubbing what so ever. I got my setup from Jon/DriverzInc. Good guys and certainly know their stuff.
Matt
zlek131 is offline
post #4 of 9 (permalink) Old Mar 16th, 10, 05:07 PM
Marc
mnm99's Avatar
See sig...1/2" clearance inner and outer.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #5 of 9 (permalink) Old Mar 23rd, 10, 08:31 PM
Jerry R.
jr68's Avatar
-shoe
Jeff I just made a template to see if I could fit a 255/50/17 on 17" TTII's with 4.5" bs on the back of my 68 and I found they will just fit inside the fenderwell and I wouldnt go any bigger than that unless you want them to rub.
I have 275/50/15 now and they are 1/4" wider but the inadequate back spacing of the rims they're on make them rub.
But that 255 is the biggest I can stuff in there.
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #6 of 9 (permalink) Old Mar 23rd, 10, 09:02 PM
Steiner
I have the same as Marc. If you want to save some coin and not wait for the TT's to be built (unless you can find the right backspacing in stock somewhere), you can do the MB Wheels Old Schools with tires mounted, balanced, and to your door for less than what the TT's alone would cost.
https://www.camaros.net/forums/showthread.php?t=152694
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 9 (permalink) Old Mar 23rd, 10, 09:04 PM Thread Starter
Jeff
I had a great deal on a pair of new TT II's, 17X8, but of course the 4.75 backspacing he claimed turned out to be 4 inches even...UGH! Craigslist is simply full of retards! They seem so close to fitting but from what everyone has said, that 4" is a recipe for disaster if I try to run them. Funny how 3/4" can make such a difference. So, back to shopping for the elusive great deal on new wheels, without the new store prices.
-shoe
Old
shoe is offline
post #8 of 9 (permalink) Old Mar 24th, 10, 09:55 AM
Dr. Feelgood
-shoe
You should see what a difference .25 makes...or removing the top inner fender bolt...sometimes it comes down to fractions between what works and what rubs.
I'd contact Jon or Justin over @ www.driverzinc.com for expert fitment advice and great selection & pricing.
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
post #9 of 9 (permalink) Old Mar 24th, 10, 10:14 AM
Rick
More negative camber!
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
