3.07 Gears With A 4spd? - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 15th, 10, 09:18 PM Thread Starter
Dean
My original 12 bolt is a 3.07, I'm converting to a M20, I know these gears are on the high side but with the lower 1st gear in the M20 is there any chance it will be acceptable or should I just go to 3.55's while I have the car apart? this is just a stock L48 I'm not out to drag race I just want a street car.
440sixpack is offline
post #2 of 6 (permalink) Old Mar 15th, 10, 09:19 PM Thread Starter
Dean
Re: 3.07 Gears With A 4spd?
Sorry I think I have this in the wrong section.
post #3 of 6 (permalink) Old Mar 16th, 10, 01:28 AM
mark
With the wide ratio M20 the 3.07 should be fine. Will do real good on the highway thats for sure. mark
stroud6 is offline
post #4 of 6 (permalink) Old Mar 16th, 10, 07:37 AM
The car will run and move. First gear will last a long time and it won't be as easy to spin tire as it would with a lower rear gear like 3.55 or 3.73 but you can always change rear gears later. As Mark said, Definitely good on the highway.
Melrose RS is offline
post #5 of 6 (permalink) Old Mar 16th, 10, 07:44 AM
Brandon
Dean it's pretty much what I'm running with a 3.08 and wide ratio M20.. I can still spin the tires too. Freeway driving is nice, first is a bit long winded and intown driving is typically between 2nd and third and fourth if the speed zone is 45.
Brandon J. licence 1NASTY67
Nantooch is offline
post #6 of 6 (permalink) Old Mar 16th, 10, 08:28 AM
Rene
rsbecool's Avatar
For what you listed you will be fine as is.
68 rs 350
M-20 4-speed
10 bolt 8.5 3.23
TC #24
rsbecool is offline
