Weld wheels - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 23rd, 10, 09:09 AM Thread Starter
Weld wheels
Was looking for wheels and found a pair of weld draglite skinnies locally. They have weld center caps, and that is the only thing that tells me they are the real deal. They have metal valve stems with a metal nut hold down. Cant find and markings ??? They have old rubber on, is there some ID under there?? thanks larry
Larry
macdon is offline
post #2 of 10 (permalink) Old Mar 23rd, 10, 03:17 PM
Lance
Re: weld wheels
I bought my car with Welds. Always thought they were different in that the hub of the wheel is hollow with an aluminum wheel spacer like piece in the middle.
Spitfire44 is offline
post #3 of 10 (permalink) Old Mar 23rd, 10, 03:37 PM Thread Starter
Re: weld wheels
Thanks Lance
OK , these wheels have some sort of metal spacer as you described. Lookin good !! Do your wheels have any markings or producer code anywhere on the metal.
Larry
macdon is offline
post #4 of 10 (permalink) Old Mar 23rd, 10, 03:52 PM
Re: weld wheels
When I bought mine they were stamped Weld Wheel around the hole where the cap goes... 2 were damaged in my accident and were replaced with new ones... neither is stamped but the shop showed me the receipt from Summit and they were Welds.(no markings at all)
68 Camaro~LSx ~all motor
post #5 of 10 (permalink) Old Mar 23rd, 10, 04:25 PM
Re: weld wheels
Originally Posted by macdon View Post
....Do your wheels have any markings or producer code anywhere on the metal.
My Weld Racing Pro Stars,which are still on my Camaro(bought new from Summit Racing in the late '90's)have markings as follows :
  • Weld Racing
  • Pro Star
  • Street Legal
  • Aluminum
  • Manufacturing Date xx-xx
David F.
www.firstgens.com
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #6 of 10 (permalink) Old Mar 23rd, 10, 04:28 PM
Re: weld wheels
All wheels have had marks for many years, some are in code, read all these posts
about someone for date code ralley's, all wheeles have some marks.
john68 is offline
post #7 of 10 (permalink) Old Mar 24th, 10, 10:33 AM Thread Starter
Re: weld wheels
thanks guys. No exterior markings , going to pull the rubber off tomorrow and see if they are stamped . They seem real, I will order a pair of 15x8 for the rears.
Larry
macdon is offline
post #8 of 10 (permalink) Old Mar 25th, 10, 08:11 AM
JWA
Jeff
JWA's Avatar
Re: weld wheels
Typically the ones I have seen with no stampings with Weld Racing center caps are actually the Cragar equivalent. Usually the stamping will have the manufacture date stamped on them next to the hub logo. At one point I had 22 drag lite wheels and all of them had the stamped hub logo.
i went and looked at Weld's website and it does look like the stamped logo is no longer there.
The summit pic might be older and you can barely see the stamped logo.
I don't think Cragar makes the draglite style wheel anymore. However Summit and Jeg's have a Chinese version but the center hub is vastly different (no dual pattern).
Summit's:
Addicted to projects...
I just wanna drive........
JWA is offline
post #9 of 10 (permalink) Old Mar 26th, 10, 12:54 PM Thread Starter
Re: weld wheels
Jeff,
thanks for the investigation, I saw the summit wheels but prefer the weld's. Not just for the matching look, I have issues with the chinese metal products. ( was in aerospace and worked there for a few years !!) Pretty sure Weld still manufactures in the USA so I plan to buy those from Summit.
Larry
macdon is offline
post #10 of 10 (permalink) Old Mar 26th, 10, 07:36 PM
JWA
Jeff
JWA's Avatar
Re: weld wheels
yep Weld wheels are built in Kansas City.
JWA is offline
