Goodyear Polyglas F70 15 - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 4th, 10, 08:04 AM Thread Starter
J
Can someone help and provide the recommended tire pressure for the polyglas F70 15. I live in Los Angeles.
Thanks in advance.
jkkrs310 is offline
post #2 of 3 (permalink) Old Apr 4th, 10, 02:54 PM
Jeff
Re: Goodyear Polyglas F70 15
The sidewalls on my reproduction F70x15 Polyglas tires state 32 psi maximum and I have been filling them to 32 psi when they're cold. However, the sticker inside the door on a 1969 Z/28 recommends 26 cool and 32 hot for the original E70x15 tires, so you might want to use those guidelines instead.
No first-gen Camaros were originally equipped with F70x15 tires, so I don't think you'll find any GM recommendations for that exact tire size.
-Jeff
JeffD is offline
post #3 of 3 (permalink) Old Apr 5th, 10, 09:44 AM
Dr. Feelgood
Those tires have a pretty good size sidewall buldge and I can tell you they do not like low tire pressure...I run mine @ 35lbs...as I do with all my other tires,seems about perfect.
The Polyglas tires will flat-spot if they sit for a long period of time but generally that goes away after a short drive or if they are driven on regularly.
You shouldn't have any problem in a warm weather climate like CA...
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
