15x8 rear wheel backspacing - Team Camaro Tech
post #1 of 5 (permalink) Old May 2nd, 10, 04:48 PM Thread Starter
Darko
well my rear end is 1" narrower than stock and I want to run a 15x8 torque thrust II with a 275/60/15 m/t street radial.
For you guys with a 275/60/15 and a 15x8 wheel with 4.5" backspacing. Is there a 1/2" clearance towards the body of the car? If there is I hopefully shouldnt have a problem.
darko is offline
post #2 of 5 (permalink) Old May 2nd, 10, 05:52 PM
Chris
Re: 15x8 rear wheel backspacing
There is on mine, I could run a 275 but needed just a little more room so they wouldn't rub when hitting a hard dip in the road. I switched to 255s. You should have it made. 275s really fill up the wheel well nicely.
hirpms is offline
post #3 of 5 (permalink) Old May 3rd, 10, 05:40 PM
wayne
Send a message via Yahoo to wayne mcsherry
what is the bs ihave a 8x15 4in bs want 255 60 what about a trim ring that will fit
wayne mcsherry is offline
post #4 of 5 (permalink) Old May 3rd, 10, 05:44 PM
4.25" may be best for you ?
I have 15 x 8 with 4.5 BS and 275's... I can get my fingers between tire and wheelwell.
68 Camaro~LSx ~all motor
post #5 of 5 (permalink) Old May 6th, 10, 06:28 PM
Dee
Doug,
Are you saying you can get your fingers between the tire and inner wheel well, or between the tire and the fender/wheel opening trim? Or both?
I'm wanting to go 15x8 Cragar SS wheels with 276/60/15s on the rear of my '69. But I'm also concerned about clearance.
Any pics?
1967 RS/SS350 Camaro (mostly stock)
1969 RS/SS Camaro (being improved!)
1967 Plum is offline
