Anyone with a 275/60/15 m/t street radial on a 15x8 wheel?? BIG Favor! - Team Camaro Tech
post #1 of 8 (permalink) Old May 12th, 10, 07:01 AM Thread Starter
Darko
If anyone has a set laying around I need to know how much the tires buldge on the wheel. I need to order custom backspaced wheels since i have a non factory rear axle and want to make sure i'm not rubbing. So a straight edge along both the front and back face of the wheel and that distance measured would be awesome if someone had a spare second to help someone out
darko is offline
post #2 of 8 (permalink) Old May 13th, 10, 07:03 PM
mark
Re: Anyone with a 275/60/15 m/t street radial on a 15x8 wheel?? BIG Fa
I have the exact same combo 275/60/15 MT ET streets on weld 15x8 pro-stars. I'll get you the measurments friday after I get off work if you still need them then.
sick67 is offline
post #3 of 8 (permalink) Old May 13th, 10, 09:10 PM
Allen
ID:	15824I just happen to have a set of 8" centerlines with 275/60/15 mt street radials on them. I layed a square level across tire and measured to rim. The measurement on front is 1 1/16" the rear is 1", this is to outside edge of rim. Here are some pics.
69 X-11 RS Conv. Deluxe Int, PW, PT.
69 X-11, Column shift, 350, 12 bolt 4:11, Yenko Clone
68 SS clone, tach, console gauges, 355 with 700R4
67 RS/SS clone, BB, Auto, 12 bolt 4:11
racin67cam is offline
post #4 of 8 (permalink) Old May 14th, 10, 03:49 AM Thread Starter
Darko
Originally Posted by racin67cam View Post
Attachment 15821
Attachment 15822
Attachment 15823
Attachment 15824I just happen to have a set of 8" centerlines with 275/60/15 mt street radials on them. I layed a square level across tire and measured to rim. The measurement on front is 1 1/16" the rear is 1", this is to outside edge of rim. Here are some pics.
so how wide does that make the total tire? Is there anyway you could get the measurement from the ground to the square you have laying on the tire? That would get the measurement I need.
thanks for the help!!!
darko is offline
post #5 of 8 (permalink) Old May 14th, 10, 06:54 PM
mark
I came up with 1 1/16 front and rear. I cant find my tire pressure gauge but I'll look again tomorrow as that will probably affect the buldging a small amount
sick67 is offline
post #6 of 8 (permalink) Old May 16th, 10, 06:57 AM
Yes I agree. I think you could find it somwhere in your garage. I hope you can.
tiresmokindad is offline
post #7 of 8 (permalink) Old May 17th, 10, 06:21 AM Thread Starter
Darko
you mean 11 1/16? Seems like 1 1/16 is a pretty narrow tire
darko is offline
post #8 of 8 (permalink) Old May 17th, 10, 02:51 PM
Darko, 275mm is the sidewall section width. That equates to @ 10.875" or 10 7/8".
Also a member of
Blown 67 is offline
