17x9.5 rear tire question - Team Camaro Tech
post #1 of 14 (permalink) Old May 12th, 10, 12:25 PM Thread Starter
Louis
You guys that are running 17x9.5 wheels with a 275/40/17 rear tire. Do you have to relocate the rear shocks in order to do this? Is there any trimming or rolling of the lip to fit this combo on a 69 camaro with a gm 12bolt? Any input is appreciated, thanks.
Louis
YBUYAV8 is offline
post #2 of 14 (permalink) Old May 12th, 10, 01:47 PM
Re: 17x9.5 rear tire question
No you don't have to move the lower shock location, you may have to roller the Qtr lip all depends on your Camaro each one is a little different.But a 275/40/17 will fit with no problem. I'm running a 275/40/18 on mine zero issues, with 5.75 back space. Would have been nice to get a BS of 5.80 tho to me seems like 5.80 bs would tuck it a little better.
69RS-Yenko is offline
post #3 of 14 (permalink) Old May 12th, 10, 05:02 PM
Steiner
Mine fit perfect. I do get slight rubbing on the upper inner fender on hard curves and have been thinking about either an 1/8" spacer or just taking the sledge to them. Thought my TrueTrac was acting up until I realized that the tires had a tight fin or gill pattern on the sidewall and it almost made a whining sound when they touched.
'69 Camaro
275/40-ZR17 on 17x9.5 with 5.5" backspace on a Moser first gen crate rear end and Right Stuff discs.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 14 (permalink) Old May 13th, 10, 04:17 AM
Markus
Hello!
I installed 17x9,5 LT 1 Corvette wheels with 2" spacers. I had little rubbing on the inside with 255/50/17. And nearly no clearence on the outside. Sorry I couldn't imagine 275 without rubbing. I had hotchkis three leave springs, Hellwig stabi and koni shocks, pu bushings all over. So the car is very stiff. With the new leave springs I think there is no rubbing any more. In normal stance there is enough clearence to the inner fender but if you have slant terrain the tire goes extremely close to the chassis because your axle and chassis horizontal is now not parallel. You must decrease this movement => stiffer springs, stabi etc..
I have these special terrain every time I'm driving because the yard in front of my garage has this shape. The chassis front tilts to the left on the street but the rear axle is still on the yard => rubbing (in the past). But you can drive on a wedge with one rear wheel without seeing any rubbing.
69`Camaro, 92`LT 1 / 94' BW-6 speed, shorty headers+Flowmaster, Vette wheels, Eibach/hotchkis springs, koni shocks, Nova rear, Corvette 13" front brake system
[all certified by German association for technical inspection with Oldtimer title]
Markus is offline
post #5 of 14 (permalink) Old May 13th, 10, 05:06 AM
Steiner,
Do you have any side pics of your car?...I'm thinking of going with 17" Cragar SS wheels on my 69. It's a multi-leaf car, with Caltracs and Edlebrock shocks, and I'm wondering if they'll fit. I can see in the pic above that your rear tires aren't tucked up inside the wheel well, which is the look I'm going for.
Hanging on the Maine Coast...moved back North
1969 RS/SS, 383, 4spd, 373s, 12bolt, FatMat, Vintage Air - Super Red, and it's my first Camaro.
Engine pics
Radiator pics
Build album
Lobstah is offline
post #6 of 14 (permalink) Old May 13th, 10, 06:27 AM
Steiner
Originally Posted by Lobstah View Post
Steiner,
Bad angle maybe. The front and rear tire edges are physically inside the upper fender lips. I've got four leaf reproduction leafs with no drop and Eibach 1" lower front coils. The pics are from right after install so it's settled some now.
Here's a couple I went out and shot in the garage just now.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 14 (permalink) Old May 13th, 10, 07:12 PM
Patrick
If I'm not mistaked I believe we rolled the lip ever so slightly. My 18's fit very well. It's the fronts that scrub sometimes when I turn only because it is lowered.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #8 of 14 (permalink) Old May 13th, 10, 07:41 PM
Thanks...what wheels are you using? They look almost like a Foose...
Engine pics
Radiator pics
Build album
Lobstah is offline
post #9 of 14 (permalink) Old May 13th, 10, 07:47 PM
285/40-ZR17 on 17x9.5 with 5.5" backspace
Moser first gen crate rear end and touring classic 12" chevy rotors.
Trimmed quarters
mtrhead is offline
post #10 of 14 (permalink) Old May 13th, 10, 07:51 PM
Steiner
MB Wheels "Old School" from Discount Tire Direct. Might be made in the same factory as the Coy wheels. The center cap is the same with the oval indention but it's blank. Need to get some black bowtie stickers or something to go in there.
https://www.camaros.net/forums/showthread.php?t=152694
'69 Camaro
500hp/538lbft
Steiner is offline
post #11 of 14 (permalink) Old May 14th, 10, 09:18 AM
Matt
I run 18x9 5.25BS with 275/40. I had very slight rub on the inner wheel well on steeps and turns. A 1/4" spacer did the trick. I was worried that I may have to roll the lip but did not have to after all. When the rear compresses the tires actually angle a bit towards the middle of the car so what may look like a potential lip rub may actually be just fine.
Matt
zlek131 is offline
post #12 of 14 (permalink) Old May 14th, 10, 09:32 AM
dondb's Avatar
I just bought a set of Vww 45's 17*9 and the rear tires are 275's nitto 555's and they have a full inch inside and 3/4 outside. The wheels i took off were 16*9's and the tires were 255's....when i measured the tire width's they were the same 10.5 inches, so with that said, make sure you look at the manufacturers tire widths
69 X-44 Camaro, slowly upgrading to my liking...Hmmm, i guess i'll never be done
2002 Camaro LE SS...Many upgrades
1969 Step Side LWB C10
dondb is offline
post #13 of 14 (permalink) Old May 14th, 10, 12:46 PM
Dr. Feelgood
A 17x9.5 w/5.5" b/s and a 275/40 tire is an absolute bolt-on w/no modifications...
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
post #14 of 14 (permalink) Old May 15th, 10, 08:28 AM Thread Starter
Louis
Guys, thanks for the pics and info. I went ahead and ordered my wheels and tires last night. I went with a Centerline Laser wheel and the new Nitto 5R drag radial. I will post some pics when the wheels come in, should be about three weeks or so for centerline to make the wheels. Here is a pic of my 69 with the TTII's, I'm currently running. The TTII's will be up for sale when the new wheels arrive. They are 17x7 fronts and 17x8 rears. Thanks again for the help.
Louis
Name:	69 Camaro 002.jpg
YBUYAV8 is offline
