69 Camaro Rims - Team Camaro Tech
post #1 of 4 (permalink) Old May 20th, 10, 06:21 PM Thread Starter
Chris
69 Camaro Rims
I have a 69 SS camaro 350 with a 12bolt rear and disc brakes. As of right now the suspension is stock. I want to get either a set of torq thrust II or a set of torq thrust M. I want to know what is the best backspacing to use with a 17" rim. I guess I would want to put the largest tires in the rear without having to worry about rubbing. Also is it worth it to get the torq thrust II with the custom back spacing or would the torq thrust M series be fine with its stock back spacing? I guess if I put a set of 40 seris tires on it, it would look good lower maybe an inch any opinions? Thanks alot guys!
chevy17 is offline
post #2 of 4 (permalink) Old May 21st, 10, 05:59 AM
Kevin
KevinW's Avatar
Re: 69 Camaro Rims
Welcome Chris!
Sorry I cannot help on the non stock wheel question, but are you selling your YJ rims then?
Kevin
KevinW is offline
post #3 of 4 (permalink) Old May 21st, 10, 01:28 PM
Dr. Feelgood
Re: 69 Camaro Rims
Here's what will work best on your Camaro...
Fronts:
17x8 (4.75" b/s) 245/45-17's
Rears:
17x9.5 (5.5" b/s) 275/40-17's
These should fit w/o issues...
Contact Jon Henson @ www.driverzinc.com for further expert fitment advice and great pricing on tire/wheel packages...
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
post #4 of 4 (permalink) Old May 21st, 10, 06:21 PM Thread Starter
Chris
Re: 69 Camaro Rims
Thanks guys
chevy17 is offline
