17 s on a 1968 - Team Camaro Tech
post #1 of 8 (permalink) Old May 28th, 10, 11:15 AM Thread Starter
Apprentice
tim
tabragg's Avatar
17 s on a 1968
i have four new bfg 17 inch tires off of a 1994 corvette. 285/40 zr17 and 255/45 zr 17. will these fit my 68 camaro ?what back spacing should i look for? the car has stock suspension and it is not tubed. any input would be appreciated.
a poor man has poor ways.
tabragg is offline
post #2 of 8 (permalink) Old Jun 6th, 10, 07:39 PM Thread Starter
Apprentice
tim
tabragg's Avatar
Re: 17 s on a 1968
maybe some help from a moderator?
tabragg is offline
post #3 of 8 (permalink) Old Jun 6th, 10, 10:01 PM
Re: 17 s on a 1968
do a search on here for largest tire, etc. From my limited knowledge....mostly gained here...245s on front and 275s on back. I have heard that some have gone a little bigger but your back space has to be right on and you might still have rubbing issues.
68 coupe ,572,tko
Denvervet is offline
post #4 of 8 (permalink) Old Jun 7th, 10, 03:55 AM Thread Starter
Apprentice
tim
tabragg's Avatar
Re: 17 s on a 1968
thank you very much.
tabragg is offline
post #5 of 8 (permalink) Old Jun 7th, 10, 05:44 PM
Re: 17 s on a 1968
Hello
I have a 68 and run 17x7 with 4 in back spare on the front and 17x9.5 with a 4.75 back space on the back. I wish that I would have put 4.5 on the back as I am running 275 50 17 tires on the back and 215 40 17 on the front and the back ones are slightly rubbing the inside on the wheel well.
1968 396 SS Red/Red Deluxe interior.
Been updated to a 460ci
Powerjection 1
700r4
oirginal 12 Bolt.
1968 Camaro is offline
post #6 of 8 (permalink) Old Jun 8th, 10, 09:00 PM
Robert
ROBS6T8's Avatar
Re: 17 s on a 1968
Good info John. Any pics?
Robert
68 Camaro SS... getting there!!
"If happiness is in your destiny, you need not be in a hurry."
If I can only convince myself of this!
My slooow build thread
ROBS6T8 is offline
post #7 of 8 (permalink) Old Jun 9th, 10, 05:58 PM Thread Starter
Apprentice
tim
tabragg's Avatar
Re: 17 s on a 1968
thanks john . this info will same me so time .
tabragg is offline
post #8 of 8 (permalink) Old Jun 15th, 10, 06:18 PM
Re: 17 s on a 1968
For a 17x8 front, you should be looking for a 5.00" BS with that tire, or very close to it. For the rear a 17x9.5 with a 5.5-5.75" backspace or close to it. I am going to warn you that those tires are just a tad bit wider than what we normally recommend. We normally recommend 245/45 fronts and 275/40 rears on first gen camaros. With running the slightly wider tires you mentioned, a little extra backspace would only help you out, which is what I recommended.
DriverzInc is offline
