17X8 with 4 in bs and 255/45/17's on the rear of a 69? - Team Camaro Tech
post #1 of 19 (permalink) Old Jun 7th, 10, 01:46 PM Thread Starter
Jeremy
Question 17X8 with 4 in bs and 255/45/17's on the rear of a 69?
I have a line on a couple of these new for less than 200 a pc... was wondering if I ran this wheel and tire combo on the back, if it would work okay? I could run 255/50/17's as well, that might be a hair narrower. Any help would be greatly appreciated!
69 Camaro Finally restored. New 496, 700R4, 3200 stall, 3.90 12 bolt posi
LYK2ROC is offline
post #2 of 19 (permalink) Old Jun 7th, 10, 06:48 PM
Steiner
Re: 17X8 with 4 in bs and 255/45/17's on the rear of a 69?
I think they'll stick out. Even 15x7's run 4.25" backspacing.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 19 (permalink) Old Jun 7th, 10, 07:39 PM Thread Starter
Jeremy
I have 15X7's with 3.5 in bs with 255/60R15 Radial TA's and they bulge a bit, but they don't rub... I figure it would be close, but not positive...
LYK2ROC is offline
post #4 of 19 (permalink) Old Jun 8th, 10, 08:09 AM
Ted
Jeremy, welcome fellow Iowan. Check out the sticky on the 69 combos. I see one guy is running 17x8 with 4.75 bs. He has 255/45's on the rear. I don't know if that .75 of an inch bs will cause you to stick out to far. If the seller is close to you ask them if you can try fitting one wheel on and see.
tgifford5 is offline
post #5 of 19 (permalink) Old Jun 8th, 10, 11:18 AM Thread Starter
Jeremy
Thanks Ted! I have checked that many times, but it doesn't answer my question... I got taken on Ebay and got one that is 5.5 in bs... seller would never respond... 100% positive feedback I think it would be very close...
LYK2ROC is offline
post #6 of 19 (permalink) Old Jun 8th, 10, 12:29 PM
Dr. Feelgood
Will not work...4" b/s isn't enough and will have you rubbing the fenders.
4.5" on a 8" wide wheel is a minimum on these cars and even that is tight.
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
post #7 of 19 (permalink) Old Jun 8th, 10, 12:37 PM
Ted
Listen to your DR. Jeremy, are you going to the Good Guys show at the fairgrounds? July 4th wkend
post #8 of 19 (permalink) Old Jun 12th, 10, 08:14 PM Thread Starter
Jeremy
Yep... I'll be there Friday and Saturday... Maybe some on the 4th... I enjoy that... I went to the Hot Rod Power Tour in Newton, and wasn't all that impressed... I think the Good Guys is a better show.. so I am pumped.
LYK2ROC is offline
post #9 of 19 (permalink) Old Jun 15th, 10, 06:00 PM
Good Guys always puts on a good show. Have fun you guys!
As for the wheels, we normally run a 9" wheel in the back with a 5.25" BS, and that is tight, so a 8 with a 4" is going to be a .25" even further outboard from where we like it to be, and that is not good. Ideally, an 8 with a 4.5" is about where you want to be. Some TT2s come "standard" with 4.75", and even that is okay.
DriverzInc is offline
post #10 of 19 (permalink) Old Jun 15th, 10, 07:00 PM
they will fit i just sold a set of 17 x 8 rears with 245/50 17 on them and they had no problem they were a 4 inch back space also, i have a picture if you want to see
6t9z is offline
post #11 of 19 (permalink) Old Jun 15th, 10, 07:55 PM
i forgot to mention that this car had air shocks, i am not sure about a stock shock car
6t9z is offline
post #12 of 19 (permalink) Old Jun 16th, 10, 06:19 AM Thread Starter
Jeremy
Damn... wish I would have known that before now... those wheels are long gone... I thought they would work by the way my 255's sit on there now with a 15X7 and 3.5" bs... they don't even come close to rubbing anywhere... and no I don't have air shocks, but my car sits much higher than yours in the rear end... so much you can see my aluminum differential cover... thanks for the info... It is much appreciated...
LYK2ROC is offline
post #13 of 19 (permalink) Old Jun 16th, 10, 06:41 AM
Steiner
I guess it depends on the look you're after. Tucked or untucked. This is a 275/40ZR17 on a 9.5" rim with 5.5" backspacing.
MB Wheels Old School in chrome
front - 17x8, 4.75" backspace, 235/45R17 Hankooks
rear - 17x9.5, 5.5" backspace, 275/40R17 Hankooks
$1176 mounted, balanced, and shipped from discounttiredirect.com
$750 for the rims alone
Even less for the gunmetal finish.
'69 Camaro
500hp/538lbft
Steiner is offline
post #14 of 19 (permalink) Old Jun 16th, 10, 11:14 AM
This car, lowered, looks to me like it would definitely rub.
post #15 of 19 (permalink) Old Jun 16th, 10, 01:43 PM Thread Starter
Jeremy
Yep... That is what I was thinking... it may rub... really close to the outer lip... I hate the fact that you have to run such a short tire that is wide... 25.3 in (275/40R17) is just too short with my 3.90's... With my setup now... it is right at 2600-2800 rpm at 70 mph..just about perfect... I hate to see what cutting it down 2 inches will do...
LYK2ROC is offline
