what is the correct back-spacing? - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 21st, 10, 06:09 PM Thread Starter
Keith
I have a '67 Camaro, 15X7 rally wheels all the way around...
I run BF Goodrich 255/60/R15 on the rear, and from the looks of the tires, they may be slightly rubbing the shock mounts from time to time.
I can likely fix te issue with a small spacer, but was wondering what teh corrcet backspacing of the wheels is "supposed: to be.
I don't know if it makes a difference, ut I am running multi-leaf as well.
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #2 of 3 (permalink) Old Jun 21st, 10, 07:07 PM
Jeremy
Re: what is the correct back-spacing?
With the 255/60R15's you need a 4.5 in bs... I run 7's 3.5 bs with a 255 but mine is a 69 with multi leafs... they bulge out a bit but they don't rub, but they are close.
69 Camaro Finally restored. New 496, 700R4, 3200 stall, 3.90 12 bolt posi
LYK2ROC is offline
post #3 of 3 (permalink) Old Jun 24th, 10, 04:15 PM Thread Starter
Keith
Thanks...Now I just have to measure what's on the car...wheel shave been on there for years--ran spacers for a while. Took them off a couple of years ago, but am just starting to see some wear marrs consistent with rubbing the shock mount...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
