Wheel Bolt circle - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 27th, 10, 03:49 PM Thread Starter
Wheel Bolt circle
This is driving me crazy!
I keep seeing 5x4-3/4" & 5x4-1/2"
What is the wheel bolt pattern or circle for a 1969 Camaro 12-bolt rear end?
camaro434 is offline
post #2 of 6 (permalink) Old Jul 27th, 10, 04:40 PM
mike
Re: Wheel Bolt circle
5 on 4 3/4 at least thats what my 67&6810 bolt rear is...5 on4 1/2 is a ford thing i think ...
kamloops67 is offline
post #3 of 6 (permalink) Old Jul 27th, 10, 04:42 PM
Vintage 68's Avatar
Thumbs up Re: Wheel Bolt circle
Almost all mid-sized GM (Camaro, Chevelle, Corvette, some ChevyII/Nova) were 5 X 4 3/4" (5 lug on a 4.750" circle ...)
Same 4 3/4" pattern for most 10 (8.2~8.5") and 'car' 12-bolts.
Most mid~full size Ford (and most trailer patterns) are 5 X 4 1/2" ... as are many Chrysler products over the years
Lots of 'if-and-but' exceptions to that, depending on year, option & ect. - but it's a good starting place ...
Sorry - Mike types faster than me ... but so does most every one else
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 6 (permalink) Old Jul 27th, 10, 04:48 PM Thread Starter
Thanks guys, I did some more research & I think your right 5 x 4-3/4"
post #5 of 6 (permalink) Old Jul 29th, 10, 04:53 PM
Dr. Feelgood
That is correct...
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
post #6 of 6 (permalink) Old Jul 29th, 10, 09:58 PM
i know this is somewhat beyond the scope of the question at hand, but it might be useful to have if someone is doing some searching in the future..
as a general rule, any rwd GM car with 5 lug wheels since at least the 50's will be a 5X4.75" bolt pattern- up to and including the brand new Corvettes.
they used a 7/16" stud until '80, and went to a slightly bigger 12mm stud after that.
the new Camaro, Pontiac G8, and the 04-06 GTO use a slightly smaller bolt pattern, but the difference is on the order of half a millimeter smaller..
every S series truck ever built from '82 until they were phased out in '04 or so had the 5X4.75 bolt pattern.
the full size cars with HD suspensions (wagons, cop cars, etc) have the bigger 5X5" bolt pattern with a bigger center pilot hub diameter, and the 1/2 ton 2wd pickups up to '98 also used the 5X5 wheel bolt pattern. they had 1/2" studs up until the late 80's or early 90's, then i think they went to the same 12mm stud as the cars after that.
the smaller 5X4.5" bolt pattern was (and still is) popular in passenger cars with Ford (rwd cars and ranger trucks), Mopar (fullsize fwd like the LH series Intrepids and what not and all rwd cars including the new Chargers and Challengers), AMC, and trailer applications.
you don't plan sincerity.
novaderrik is offline
