tire size for 10x15 wheels - Team Camaro Tech
post #1 of 12 (permalink) Old Aug 2nd, 10, 04:29 PM Thread Starter
steven
what is a good tire size for a 10x15 wheel, car has mini tubes with a latter bar set.
hotrod01 is offline
post #2 of 12 (permalink) Old Aug 2nd, 10, 04:31 PM
Steve69SS396's Avatar
Re: tire size for 10x15 wheels
Drag slick, street radial, drag radial?
Steve69SS396 is offline
post #3 of 12 (permalink) Old Aug 2nd, 10, 04:40 PM Thread Starter
steven
street radial
hotrod01 is offline
post #4 of 12 (permalink) Old Aug 2nd, 10, 04:56 PM
This tire from Mickey Thompson would be a good street tire for a mini tubbed car with a 10" rim. http://www.summitracing.com/parts/MTT-6641/
With a stock wheel opening the max diameter you will be able to run is 28". MT has tires wider and narrower than this for 15" rims.
What brand of mini tubs were installed?
post #5 of 12 (permalink) Old Aug 2nd, 10, 05:03 PM Thread Starter
steven
they are homemade with about 2.5-3 inch clearance
hotrod01 is offline
post #6 of 12 (permalink) Old Aug 2nd, 10, 06:21 PM
It sounds like the original tubs were widened? Were the shock mounts moved inboard? What about the springs, were they moved in?
You are going to need to get the car up in the air with jack stands under the rear end housing and take a bunch of measurements. Do you already have the rims? The back spacing on the rim may limit your tire size.
My car was mini tubbed using steel tubs from Chris Alston. The frame was notched, springs moved in, shocks relocated and wheel openings trimmed. I run 29" x 14.5 Hoosier Quick Time Pro tires.
post #7 of 12 (permalink) Old Aug 2nd, 10, 06:25 PM Thread Starter
steven
its ladder bars with coil overs, the leaf springs are gone
hotrod01 is offline
post #8 of 12 (permalink) Old Aug 2nd, 10, 07:17 PM
george
[QUOTE=Steve69SS396;1461080]This tire from Mickey Thompson would be a good street tire for a mini tubbed car with a 10" rim. http://www.summitracing.com/parts/MTT-6641/
I have to agree^
I see no mention of wanting to hook hard at the track or the street, for that matter.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #9 of 12 (permalink) Old Aug 2nd, 10, 07:36 PM Thread Starter
steven
well i would like for it to hook up on the street
hotrod01 is offline
post #10 of 12 (permalink) Old Aug 2nd, 10, 07:57 PM
I forgot that was in your first post. I was thinking of all the things I had to do with my car. If you want a tire that will hook I would recommend the Hoosier Quick Time Pro's. However, they won't last long and you don't want to get caught in the rain with them.
post #11 of 12 (permalink) Old Aug 3rd, 10, 12:34 PM
Tony
71maligreen's Avatar
good size tire for street is 295/50/15
here they are on my 68
love them all corvettes,camaros,chevelles!!!
71maligreen is offline
post #12 of 12 (permalink) Old Aug 3rd, 10, 12:40 PM
Tony
firestone makes them in the indy 500 firehawk and they are a great tire!!! around 100 bucks a tire to!!
