? makes a tire DOT - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 18th, 10, 07:37 PM Thread Starter
Trev
madcarson's Avatar
? makes a tire DOT
I want to race in some street legal drags and they say the tires must be DOT approved,so what is the standard ? Do MT s/r drag radials fit there or are they considered a sticky tire ?
69 Resto MOD
383
madcarson is offline
post #2 of 5 (permalink) Old Aug 18th, 10, 08:53 PM
Steve69SS396's Avatar
Re: ? makes a tire DOT
The MT Sportsman SR's are a DOT tire but they will not hook like the ET Street bias ply or drag radial.
The ET street's are also DOT approved.
Steve69SS396 is online now
post #3 of 5 (permalink) Old Aug 21st, 10, 08:09 AM
Mickey Thompson's are a fine choice. Hoosier's are good as well. Scroll down to D.O.T. Drag radial http://www.hoosierracingtire.com/spe...0Drag%20Radial
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #4 of 5 (permalink) Old Aug 21st, 10, 10:48 AM
If the Mfg. puts a DOT stamp on it then it's been tested and approved by the DOT and should be legal in that class.
68 Camaro~LSx ~all motor
post #5 of 5 (permalink) Old Aug 21st, 10, 07:25 PM Thread Starter
Trev
madcarson's Avatar
thanks guys that's what I thought,some tracks see it diff.I guess
69 Resto MOD
383
