'69 Rally Wheel help - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 5th, 10, 06:49 AM Thread Starter
seeburg220's Avatar
I have 15" Rally Wheels on my '69. I'm thinking of going to 14 x 7 Rallys. I have front disc brakes. Are there any issues w/ 14" wheels and disc brakes? Were there rallys for drum cars and rallys for disc cars, and if so, what's the difference ? Thanks.
1969 / 350 / TH350 / 3.73 posi / driver
seeburg220 is offline
post #2 of 6 (permalink) Old Oct 5th, 10, 08:49 AM
Camarodude67
Re: '69 Rally Wheel help
yes 14x7 for disk brake cars and 14x6 for drum only.... or you could just buy 15 inch corvette rally which seems to be the norm.
The only time I get 14x7 is for SS or disc brake cars and looking for originality only, these are the 5 spoke rims that you woud find on 1970 Chevelles, 69 SS Camaros.
This is not my add but for reference only....
http://newhaven.craigslist.org/pts/1979856242.html
Jeff
69 Verts
camarodude67 is offline
post #3 of 6 (permalink) Old Oct 5th, 10, 10:06 AM
Kevin
KevinW's Avatar
You could get 14x6 for discs, see CRG info http://www.camaros.org/suspen.shtml#Wheels
Basically the inner hub on drum rims did not clear the calipers. I hear MCB had disc kits with calipers that will clear drum rims.
Kevin
KevinW is offline
post #4 of 6 (permalink) Old Oct 5th, 10, 12:56 PM Thread Starter
seeburg220's Avatar
Okay, just so I'm clear on this: if I buy 14 x 7 rims, I should not have any issues with them fitting on my '69 with front disc brakes ? Thanks guys !
post #5 of 6 (permalink) Old Oct 5th, 10, 04:17 PM
You can look for the code YJ next to the valve stem and you would have THE 14" rims for the disc brake cars on 69. All 69 SS cars had discs and had these rally's on them. They also have 14x7 stamped on them. I think this stamp was on the inside of rim if tire was mounted you would not see it. I could be wrong thou...
69 RS/SS X22 51-51 Dusk Blue coupe in resto......still.
69 X11 355 ci M22 3:73 12 bolt...current driver
Spooky is offline
post #6 of 6 (permalink) Old Oct 6th, 10, 07:40 AM
Jonesy's Avatar
YJ are 69 14x7 ralleys
YA are 69 14x7 SS 5 spoke wheels, these only were an option for a short time on Camaros. Also came on SS Chevelles and Novas.
Both will clear the calipers.
The codes are by the valve stem hole, here is an example
The Month of manufacture is to the left of the hole and the Day of manufacture is to the right of the hole.
Then to the right of the day, the two letter code designating the application. In this case YH or 15x7 z/28 wheel.
This wheel was made on 12-18-68. The K18 to the left of the 12 designates wheel manufacturer (K- Kelsey Hayes), Plant (1- Romulus, MI) and Year Manufactured (8 or 1968)
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
