Tire Size - Team Camaro Tech
post #1 of 10 (permalink) Old Oct 10th, 10, 06:50 PM Thread Starter
Bob
Tire Size
Would a 28" tall, 10" wide tire fit under a 69 Camaro without hitting
out fender wall. I currently have 26" tall, 10" wide MT ET Strs and
would like to get more tire under car without tubbing. Rims are 15x8
Ramrodd 69 is offline
post #2 of 10 (permalink) Old Oct 11th, 10, 11:54 AM
R/T
Jack
Re: Tire Size
I used MT DR 275/60/15 and Hoosier QTP 28-11.5-15 with trouble on my 69. 15x8 rim
Matthew 22: 37-39
R/T is offline
post #3 of 10 (permalink) Old Oct 11th, 10, 05:16 PM Thread Starter
Bob
Re: Tire Size
Nice Pic! What size tires are on that pic? Looks like you have room there.
post #4 of 10 (permalink) Old Oct 11th, 10, 05:28 PM
R/T
Jack
Re: Tire Size
MT DR 275/60/15 in the pictures.
Matthew 22: 37-39
R/T is offline
post #5 of 10 (permalink) Old Oct 11th, 10, 07:44 PM Thread Starter
Bob
Re: Tire Size
I'm figuring 28" tall, 10-1/2 which should work since it is 1"
less in width. Could maybe go 27" tall and keep the 11.5
width since the tire is 1" shorter than what you had.
post #6 of 10 (permalink) Old Oct 11th, 10, 08:04 PM
Steve69SS396's Avatar
Re: Tire Size
28X10 slick on a 10" rim.
Steve69SS396 is offline
post #7 of 10 (permalink) Old Oct 11th, 10, 10:31 PM Thread Starter
Bob
Re: Tire Size
Thanks, Nice Pics! From first pic, you seem close to fender wall. Do
tires stick out from fender wall. From 2nd pic you have no issue but
your at WOT and car is rising. Just wondering since when I bought
my Camaro it had 11-1/2 MT DR and you can see the fender well
did hit tire since it had a slash in it. But looks like I can go 28x10
but did not want tire sticking out past fender wall or at least to
much anyway and since my rim is 8" and yours is 10" I should be
OK. Once again thanks for your pics, show a lot for what I'm thinking
on doing.
post #8 of 10 (permalink) Old Oct 12th, 10, 03:07 AM
Banned
Bethanne
Nashville Beth's Avatar
Re: Tire Size
Jack,
Do your 15 x 8 wheels have 4 1/2" backspace ?
Nashville Beth is offline
post #9 of 10 (permalink) Old Oct 12th, 10, 04:40 AM Thread Starter
Bob
Re: Tire Size
Originally Posted by Nashville Beth View Post
Jack,
Yes!
post #10 of 10 (permalink) Old Oct 12th, 10, 08:49 AM
Re: Tire Size
on doing.
The lip of the wheel openings are rolled up on my car. Occasionally it would rub on the outside of the tire. It actually rubbed more on the inside of the wheel well. The tires do not stick out past the fender.
With an 8" wheel the tire will be narrower at the sidewall and should clear without rubbing. Take a look at this thread: https://www.camaros.net/forums/showthread.php?t=164572
