Confusing Wheel Code?? - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 17th, 10, 01:22 PM Thread Starter
I have four 14x6 rally wheels with the following codes:
Next to the valve stem- M56 7 valve stem 29 faJ
Inside of the wheel rim- yh 07 28 86 99 14x6 JJ Made in Canada
I assume these are Camaro wheels but not sure. Thanks for the help in advance. I can post pics if that would help.
clm69z28 is offline
post #2 of 5 (permalink) Old Oct 17th, 10, 02:06 PM
Re: Confusing Wheel Code??
I found specs on origonal rally wheels.. so i posted em on a 'disc brakes for small wheels' thread. Just click my name and go to page 2 of the thread. Hope it helps.
South of down under is offline
post #3 of 5 (permalink) Old Oct 17th, 10, 05:14 PM
Bryon
bcm66's Avatar
Wheel codes from CRG.
http://www.camaros.org/suspen.shtml#Wheels
A picture may help. Does not sound like an orignal wheel if it has a 3 letter code.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #4 of 5 (permalink) Old Oct 17th, 10, 05:41 PM Thread Starter
Here is a pic of the wheel and the codes. I don't think it is an aftermarket wheel although it was made in Canada.
I looked at the CRG site before my post but the wheel code suggests a 1976 wheel and their site did not have any wheel code information for that year.
clm69z28 is offline
post #5 of 5 (permalink) Old Oct 17th, 10, 06:05 PM
Bryon
bcm66's Avatar
Ah, not a "rally wheel" as I think of them. At least not a first gen rally wheel.
Possible second generation Camaro wheel. Not sure. Did not see code listed here on this site.
http://www.nastyz28.com/camaro/camwheel.html
You might want to search around a bit there.
CRG -
bcm66 is offline
