Wheel spacers... - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 18th, 10, 08:25 PM Thread Starter
Big Dave
Wheel spacers...
I may have to use spacers to gain the clearence i need for my rear wheels, about 5/16" or 3/8".
Its to clear the Wilwood calipers..
Wheels are my old Centerline auto drags' (15x8.5 x 4 7/8" Back space) which i would like to keep.
I would use billet ones of course, so:
Do you guys see any probs using them?
And i cant seem to find the 5/16" spacers in billet.
if you have a source for the 5/16" please let me know.
Im just trying to use the smallest spacer i can.
thanks. Dave.
'69 camaro, was orig SS 396 car.
original tranny & 12 bolt
Now:
568 ci, Merlin Pro block
Callies crank, Oliver rods
AFR CNC 325, Nash 5 speed, 9'' Ford 35 spline locker
F1 Procharger that will get on soon...
69 merlinpro565 is offline
post #2 of 2 (permalink) Old Oct 18th, 10, 08:52 PM
Steve69SS396's Avatar
Re: Wheel spacers...
I have run them for years on my car.
http://www.summitracing.com/parts/GOR-SP602/?rtype=10
Steve69SS396 is offline
