Stripped lock nut on rim ? - Team Camaro Tech
post #1 of 14 (permalink) Old Nov 3rd, 10, 09:48 PM Thread Starter
Lex
Lexlas's Avatar
Question Stripped lock nut on rim ?
How do you remove a locked lug nut that is stripped on your rim ? As i tried to put on a spare tire i was trying to remove the broken rim and all the lug nuts came off but not the special lock nut. Every time i try to turn it, it just pops right off. I'm stuck and not sure what i can do to remove it. Anyone ever had this happen to them ? Here is a picture of the stripped lug nut below.
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #2 of 14 (permalink) Old Nov 3rd, 10, 10:03 PM
Ken
Re: Stripped lock nut on rim ?
they sell special sockets that take them off
camaro67-rallysport is offline
post #3 of 14 (permalink) Old Nov 4th, 10, 03:48 AM
Or weld a nut onto it, then unscrew it.
post #4 of 14 (permalink) Old Nov 4th, 10, 05:12 AM
Try this. Make sure the other lug nut's are tight, take a 12 point socket that will not quite fit over the outside diameter of the lock and hammer it on. Use your impact to take it off. Good luck removing the lock from the socket.
My Junk.
b4wscrambler is offline
post #5 of 14 (permalink) Old Nov 4th, 10, 05:22 AM
Worse case, if it a 10 or 12 bolt, you may have to remove axle and brake drum and torch it off from inside. But I would try the weld on nut fix first. I bet Discount tire has such a nut removal tool. I have seen these reverse cut removal nut tools , Sears or Snapon Tools.
TC # 349
zdld17 is offline
post #6 of 14 (permalink) Old Nov 4th, 10, 09:27 AM
Terry
Lex, The picture of your lock lug key looks like a McGard. If it is a McGard there is a number stamped on it. Call McGard with the number and they will send you a new lock lug key.
Is the Key stripped or the inside of the lug nut stripped? If the lug nut is bad, the special socket works well. I removed a lock lug nut when I lost the key. Clamped on vice grips and turned with a big crescent wrench. Fortunately the lock lug nut wasn't torque'd on too much. McGard's ph # 800-444-5847.
IRON MAN is offline
post #7 of 14 (permalink) Old Nov 4th, 10, 11:17 AM Thread Starter
Lex
Lexlas's Avatar
I will surely check and call them, i did see a number stamped on it. Thanks again i was wondering how i'm gonna take all of them off.
Lexlas is offline
post #8 of 14 (permalink) Old Nov 10th, 10, 09:12 AM
mike
i ground a slot in the side on mine and tapped them off with a cold chisel didnt hurt any thing just protect car from sparks(obviously)
kamloops67 is offline
post #9 of 14 (permalink) Old Nov 10th, 10, 09:29 AM
Vintage 68's Avatar
Angry Re: Stripped lock nut on rim ?
And NEVER let the 'Tire-Monkeys' use a Impact on the wheel locks
Ruined a set of locks on my "X's" car while I was out of town
1968 Convertible
Some trucks
Vintage 68 is offline
post #10 of 14 (permalink) Old Nov 10th, 10, 11:30 AM
Dremel with a cutoff disk maybe. My "go-to" tool.
Melrose RS is offline
post #11 of 14 (permalink) Old Nov 11th, 10, 10:21 AM
rodent4 is offline
post #12 of 14 (permalink) Old Nov 11th, 10, 02:48 PM
Jon
Get a craftsmen deep chrome socket. When you hit it on to the lock nut the socket will crack and you will be able to take the lock nut off. I did this to all four locks on a car I purchased with out the keyed nut.
JR67RS is offline
post #13 of 14 (permalink) Old Nov 11th, 10, 05:57 PM
scblucam's Avatar
Like b4scrambler said we used to hammer an old socket on and just turn it off. Use a lifetime guarantee socket and tell them it just failed because it won't likely be any good for anything else.
68 302 M20 - 85 IROC Z
scblucam is offline
post #14 of 14 (permalink) Old Nov 11th, 10, 08:25 PM
Jeremiah
Working in the body shop busness I have to do this quite a bit. Its amazing how many people dont have the key to the wheel locks.
Find an old socket that just almost fits the lock and drive it on with a hammer.. the shock of the impact will bust it lose every time.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
