5.5 inch backspacing on rims ? - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 5th, 10, 02:59 PM Thread Starter
Lex
Lexlas's Avatar
2 15x8 Weld Prostar wheels with 5.5 inch backspacing ! This is the rims that are exactly like the ones i messed up on my 68. Now my question is - Does anyone know if these will fit my car ? Are 5.5 inch backspacing normal ? I am unsure of my inch backspacing ? Thank you
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #2 of 5 (permalink) Old Nov 5th, 10, 04:22 PM
Re: 5.5 inch backspacing on rims ?
To measure the backspace on your old wheels just lay them face down,lay a straight edge across the wheel,and measure to the flange where it bolts to the axle.
Most go 4.5" while the plus size wheel guys get away with more...
68 Camaro~LSx ~all motor
post #3 of 5 (permalink) Old Nov 5th, 10, 07:47 PM
Steiner
This is a 17"x9.5" rim with 5.5" backspacing with a 275/40ZR17 tire. With an eight inch rim, it would most likely not fill out the wheel well on the outside very well. Imagine the edge of the rim in the pic pulled in another 1.5". Then if you somehow got a 275 tire on an 8" rim to try and fill the wheel well it would (to me anyway) look too bubbled out.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 5 (permalink) Old Nov 5th, 10, 08:09 PM
Jeremiah
17/9.5 with 5.5 BS here also and they fit perfect.
would need an inch added to the outer barrels to push the tire out to look right IMO.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #5 of 5 (permalink) Old Nov 5th, 10, 09:32 PM
class67's Avatar
5.5" bs on an 8" wide rim is a bit to much I would say, especially in the front.
67 Camaro RS
class67 is offline
