67 vs 68 Question - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 22nd, 10, 11:56 AM Thread Starter
Brent
67Rally's Avatar
67 vs 68 Question
Does anyone know if the the suspension/tire/wheel combos are compatible between the 67's and 68's? Maybe that's poorly worded.
One of the upgrades I'm looking to do this winter will be a suspension upgrade and new tire/wheel combo.
I guess the question is this: If I see a suspension/tire/wheel combo on a '68, will it also work on a '67 or are there different clearance issues between the two years.
67Rally is offline
post #2 of 7 (permalink) Old Nov 22nd, 10, 12:35 PM
Camarodude67
Re: 67 vs 68 Question
Hi Brent, Should be the same for 67-69 Camaros for stock setups. Suspensions are the same except for rear ends mono vs mulit leaf setup but that should not affect tire/wheel combinations.
Jeff G.
69 Verts
camarodude67 is offline
post #3 of 7 (permalink) Old Nov 22nd, 10, 12:44 PM Thread Starter
Brent
67Rally's Avatar
Jeff G.
69 Verts
Thanks, I've been doing a ton of searches for the right ride height and tire/wheel combo. I like to go into these purchases somewhat educated.
67Rally is offline
post #4 of 7 (permalink) Old Nov 22nd, 10, 12:51 PM
Larry
larryh56's Avatar
You might want to stick with 67 and 68 because the 69s have different fenders and quarters. I have read that the 69 has a little more room and the wheel opening in the quarters is a little different. One thing I would recommend you consider is whether you will retain the stock brakes because future upgrades can change things. When I installed front discs from CPP it moved the wheels out about a 1/2".
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #5 of 7 (permalink) Old Nov 22nd, 10, 12:57 PM Thread Starter
Brent
67Rally's Avatar
Thanks for the heads up. I will definitely be doing a disc brake conversion in the near future, they are drums right now.
67Rally is offline
post #6 of 7 (permalink) Old Nov 25th, 10, 05:33 PM
Sean
I did the same upgrade from CCP, and afterwards my 225-70R 15"s which did not rub at all...started rubbing on the top of the inner fenderwells. lucky for me it was time to replace the front tires anyway, and I went with a shorted tire size.
1967 CAMARO SS/RS 350
4 SPD CONVERTIBLE
TRIPLE BLACK
SSMUNDY is offline
post #7 of 7 (permalink) Old Nov 26th, 10, 08:52 AM
mike
i remember something about shocks being different from 67-68 staggered?...different diameter...sorry dont remember ,but know there is something...i think i had to drill out a hole on traction bars on my 67 cause i ordered for 68 as 67 wasnt listed in catalogue.
kamloops67 is offline
