I can't make up my mind. Tire questions. - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 27th, 10, 03:29 PM Thread Starter
Christopher
psy4s's Avatar
When I purchased my 67 it had actual Magneseum slot wheels.
They were 14 inch. Not bad, but not great. I want to move up tp 17 inch rims, which has increased my options.
Can anyone tell me what the Metric measurement for the bolt spacing would be?
I actually like the BBS look for the German Camaro in the Wheels and Tires blog, but I need the Metric measurement so I could order them.
I am using 15in Rally wheels now,
and a possibility is the new Forged Rally Wheels, but I am afraid I may end up with Torq Thrusts.
That would not be the worst, it just seems like allot of people have them!
or
Follow my build here:
Balanced 350, Eagle rotating assy, Mahle Flat top Forged pistons, AFR 195 cylinder heads, AFR Hydrorev kit, Comp Cams Hydraulic Roller Cam, comp Pro Mag Ultra Roller Rockers, Edelbrock AirGap RPM Manifold.
Live to rev!
psy4s is offline
post #2 of 8 (permalink) Old Nov 27th, 10, 08:05 PM
Re: I can't make up my mind. Tire questions.
Std. Chevy bolt pattern is 5 x 4.75 inches.
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #3 of 8 (permalink) Old Nov 27th, 10, 08:35 PM
Steiner
5 x 120.65mm
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 8 (permalink) Old Nov 27th, 10, 09:39 PM
joseph l clance
joe clance's Avatar
if your thinking of going 17, consider going 18! there's much more tire selection in 18 vs. 17.
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
post #5 of 8 (permalink) Old Nov 27th, 10, 09:45 PM
Matt
I agree. If you're thinking 17's you'll be wishing you went 18's down the road. JMPO...
Matt
zlek131 is offline
post #6 of 8 (permalink) Old Nov 28th, 10, 09:50 AM Thread Starter
Christopher
psy4s's Avatar
Originally Posted by Steiner View Post
5 x 120.65mm
Thanks this is what I need. I really like the BBS wheels but when I tried to search their or any companies page If I put in for my car it goes to the same wheels everyone are using. I just want something that stands out, and is not just a flat cut out. I am looking to show off the powder coated Disk brakes as well.
I will also take the advise and look into 18's, since I have nothing at the moment I am open to any suggestions till the day I buy them.
Live to rev!
psy4s is offline
post #7 of 8 (permalink) Old Jan 5th, 11, 02:25 AM
Pete
You cant mix and match 5 x 4.75 with metric sizes, you will have big problems. Only use wheels that come in 5 x 4.75. 5 x 120mm seems so close but it will cause very high stress on your wheel studs possibly causing them to break, please do not use 5 x 120 on your camaro.
Pete
1968 Camaro
2009 Porsche 911 Carrera S
Pete68 is offline
post #8 of 8 (permalink) Old Jan 6th, 11, 07:03 PM Thread Starter
Christopher
psy4s's Avatar
Thank you for the warning. I think I will go with 17" Torq Thrusts. They have a modist look, and come in the correct size.
Live to rev!
psy4s is offline
