Removing locking lug nuts - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 29th, 10, 07:52 AM Thread Starter
Jelle
Hey guys,
My wheels have got locking lug nuts installed, and of course, the adapter bit wasn't included in the deal because it was nowhere to be found.
It's a long shot, but is there a chance anyone recognizes the type or so? Or does anybody have a good idea on how to remove them.
The best idea I heard so far is to weld on a regular bold, but I'm scared my wheels will get damaged that way - and I really like the wheels
Any help would be great,
thanks a lot.
Jelle
Jelle is offline
post #2 of 11 (permalink) Old Nov 29th, 10, 08:31 AM
Kevin
Re: Removing locking lug nuts
Your only choice is to remove them and buy ones where you have the key. What I have done in the past is find a 12-point socket that 'fits' and drive it on with a hammer, then remove it. Use a 1/2" drive socket. There usually is not enough material to drill a hole and use a screw extractor.
If space permits, you could try grinding two flat spots on opposite sides and then just use a Crescent wrench as an alternative.
-Kevin
'68 RS Camaro, 454 SBC
'69 Camaro, body only
MissionCritical is offline
post #3 of 11 (permalink) Old Nov 29th, 10, 09:43 AM
Those look like McGard type locks. Most Tire Stores or dealerships will have a Master Lock Removal kit, and can probably take those off for you. Snap On Tools makes a master kit also as well as other tool dealers like Mac. etc.
Otherwise you can use a big socket like mentioned and drive it over the lug nut.
FWIW - I have also had success by taking a normal open ended lug nut clamped in a pair of vise grips with the ground lead attached, and then mig welding down the centre of the open ended nut. The spatter is usually contained in the open end nut, and you can allways cut a old welding glove apart and wrap it around that area to contain the spatter.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #4 of 11 (permalink) Old Nov 30th, 10, 10:32 AM Thread Starter
Jelle
Thanks for the tips guys.
I don't car if I lose the lugs, I just want to get my wheels of for balancing and polishing..
I'll check the local car dealers, but I don't think they'll be able to help - european cars huh..
Thanks for the help! I'll get 'em of sooner or later, one way or another
Jelle is offline
post #5 of 11 (permalink) Old Nov 30th, 10, 06:52 PM
Jeff
yellow69RS's Avatar
I have removed some of those with an air chisel (used with caution).
Jeff
yellow69RS is offline
post #6 of 11 (permalink) Old Dec 1st, 10, 04:59 AM Thread Starter
Jelle
Chisel might work! Just some sharp metal chisel and some counterclockwise hammer hits might do it! Good idea!
Jelle is offline
post #7 of 11 (permalink) Old Dec 1st, 10, 05:33 AM
Arrow Re: Removing locking lug nuts
-Kevin
I have used this method one more than one occasion. Use a socket that is just smaller then the diameter of the lug and use a BFH to drive it on. I will caution you that it may ruin the socket. I usually go buy a cheap one that than be thrown away.
Good luck.
Roy
69 Firebird
68 RS TPI Camaro (in process)
mrfixit58 is offline
post #8 of 11 (permalink) Old Dec 1st, 10, 07:36 PM
TJ
Snap On makes a removal kit... kinda high for one time use but its the easiest way to get them off without damage to your wheels.
1969 Camaro 306ci., M21, 10 bolt 8.5" with 4.56s... still being put together.
z28kid is offline
post #9 of 11 (permalink) Old Dec 1st, 10, 08:23 PM
Farm Boy's Avatar
I had the same locking nuts on a Chevelle I bought 35 years ago. Just like you I didnít have the key. I drove a piece of galvanized water pipe onto the locking nuts with a big hammer and removed them with a pipe wrench. If I remember correctly it was 3/4 inch pipe about a foot long.
Farm Boy is offline
post #10 of 11 (permalink) Old Dec 4th, 10, 06:42 AM
JAY
12 point socket trick works, also around here Discount tire will do it as will most repair shops. we have 2 kits where I work. Jay
66 SS Chevyll
67 Elcamino
68 Malibu 2dr
69 Camaro Convertible
JAYARTER is offline
post #11 of 11 (permalink) Old Dec 4th, 10, 07:02 AM Thread Starter
Jelle
Looks like there's some different options to try out. Thanks guys, big help!
Jelle is offline
