Wheel Stud upgrade - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 30th, 10, 04:44 PM Thread Starter
Kurt
camsdad's Avatar
Wheel Stud upgrade
When should it be considered to upgrade from the stock 7/16"-20 wheel studs to 1/2"-20 studs?
Kurt
1969RS 14yrs into it.
383CID Lives
200R4 Trans, 3:42 Posi 12 Bolt Ready
Cold ones in the fridge. Dam, there gone. BRB
Getting closer to my goal.
camsdad is offline
post #2 of 4 (permalink) Old Nov 30th, 10, 05:21 PM
Re: Wheel Stud upgrade
Depends on use and power level your at
68 Camaro~LSx ~all motor
post #3 of 4 (permalink) Old Nov 30th, 10, 06:12 PM Thread Starter
Kurt
camsdad's Avatar
I knew someone was going to reply with that exact response.
Vast majority street pleasure driven with an occasional run down the strip. Maybe even a run or two in a closed course. Just to see how she does. With my numbers, CamQuest6 and Desk-Top Dyno estimate just shy of 500hp/Tq.
Kurt
383CID Lives
camsdad is offline
post #4 of 4 (permalink) Old Dec 1st, 10, 08:10 AM
Russ
Besides the HP (really should be torque) questions, many disc brake conversion kits use 1/2-20 so that somewhat forces an upgrade. From my past experience I'd think running with 500 lb/ft torque or more you should go to 1/2-20. Also, if you stick with OE 7/16-20 and have a high HP/torque setup you might want to go ahead and replace the studs just for safety since they are over 40 years old.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
