need 15" SS wheel opinions, suppliers & size - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 4th, 10, 08:44 AM Thread Starter
K.P. Walsh
I will be redoing my front steering & suspension over the winter and by spring & considering installing 15" SS type wheels. So far I see "ground up" sells the complete "kit" for $775.00. The other option I saw was "specialty wheel" who touts american made, however the same approximate setup with them is $915.00, I want best quality and the $100.00 isnt such a big deal. but are they all made by same company???
so far I see these 2 vendors selling similar wheels:
ground up, but only has 15X7 4.25" b/s.
specialty wheel has 15x7 4.25" (front) & 15x8 4.5" (rear) this I believe is the better choice.
1 - is there any issue with 4.25" B/s front if I want to keep the rubber mostly "in" as stock (not poking out too far) ? I had originally picked rally wheels with 4" front b/s and 4.5" rear b/s as I like the wheels that do not stick out but I really like the SS wheel look.
2- the vendor issue, I have heard varying stories with ground up. not confident plus the all 15x7 limitation.
just looking for some opinions, ideas, backspacing opinions. I have read through all 35 pages sticky and did'nt see alot of these SS wheels in there.
kevin p...................
1972.5 Camaro!
Z27LS3 is offline
post #2 of 3 (permalink) Old Dec 14th, 10, 09:42 PM
Dean
Re: need 15" SS wheel opinions, suppliers & size
Specialty is a great outfit I've bought the wheels for all my cars from them. I'm not sure who all they make wheels for but I do know they're made in the US because I pick them up at the plant in Portland. the caps and trim rings are imported though.
I'm going to put a set of 15x7 SS wheels in the backspacing you're talking about on my '69 when I get it done.they'll make you any backspace you want at little or no extra charge within the relm of what's possible.
440sixpack is offline
post #3 of 3 (permalink) Old Dec 15th, 10, 06:02 PM Thread Starter
K.P. Walsh
I'll get the usa built wheels for sure, the brake setup I have is the CPP stock spindle with brembo caliper for stock location & 11" rotor. supposedly the CPP new version is no longer pushing out 1/2" so I'll have to confirm that and call wheel mfr. I basically dont want any excess track width, i like wheels that fit properly in the wheelwells as OE did. anyone else got the CPP setup recently ?
1972.5 Camaro!
Z27LS3 is offline
