Rear wheels rubbing - Team Camaro Tech
post #1 of 23 (permalink) Old Dec 4th, 10, 02:09 PM Thread Starter
Clint
Left & Right rear tires rubbing
Just bought a 68. Have drove it only a few times, have had a little tire rub in the back, mostly the left. Today my wife was riding in the back seat, almost every time I turned into a driveway etc, they rubbed. Either way left or right. The rubbing seems to worse with a passenger in the back. My wife only weighs 96 lbs...
The tire size is 275/60/R15. Can someone tell me what is going on? Both tires have sustainal damage to them?
Thanks in advance for the help,
Chigdon is offline
post #2 of 23 (permalink) Old Dec 4th, 10, 02:25 PM Thread Starter
Clint
Rear wheels rubbing
Chigdon is offline
post #3 of 23 (permalink) Old Dec 4th, 10, 02:30 PM
Kevin
Re: Left & Right rear tires rubbing
A 275 60R15 tire is a tall tire to start with and with a light spring in the back a little weight will easily put your tire up inside the wheel housing. You probably should look at a 260 or 255 tire. Check your back spacing on your rims before doing so just to ensure its correct.
My 68's resurrection thread
Shandara is offline
post #4 of 23 (permalink) Old Dec 4th, 10, 02:34 PM
Smile Re: Left & Right rear tires rubbing
Wrong back spacing on wheels or the tires are too big. I believe 275 is the maximum tire you can have without mini tubbing, but your back spacing has to be right.
Where on the tire is it rubbing ? Inside edge or outside edge ? What is your back spacing ?
TJS69 is offline
post #5 of 23 (permalink) Old Dec 4th, 10, 02:44 PM
Re: Rear wheels rubbing
Rubbing on the outside of the tire I assume? You might have springs sagging. Checking ride height vs specifications would be a good idea. Another question that needs to be answered is what backspacing the wheels have.
69 Pace Car and 69 Hard top
srode is offline
post #6 of 23 (permalink) Old Dec 4th, 10, 04:35 PM
Nev
That's a wide tire you've go there.
What is the back space of the wheel?
Is the damage on the outside of the tire?
If so, you may need to "roll" the inside of the wheel arch to get more clearance. (I removed some metal while doing body and paint on my 68 just in case I needed a llittle more clearance)
You may need to change the wheel to a more suitable backspace.
You may need to change to a tire that is not so wide.
There are a number of options
Rgds,
Nev
Almost finished (?) 68 Camaro
383 stroker
T350
12 bolt Moser
nev68 is offline
post #7 of 23 (permalink) Old Dec 4th, 10, 04:48 PM
Jon
The only way they will fit is if you roll the lip or jack up the rear. I widened my inners and the 275' sucked right in on a 9'' rim. I have room for a 10" and will be changing this winter. The silver car is mine the purple car is stock inners.
JR67RS is offline
post #8 of 23 (permalink) Old Dec 5th, 10, 04:29 AM
alex
do you have a single leaf or multi are your shocks ok check your ride hight .probably wouldnt a bad idea to round the fender lips roll them up check your wheel spacing or offset. air shocks might ashort term cure for new springs but not too much air used them once on mine it rode like a solid axle and then broke the upper shock mounts good luck AL
ss27 is offline
post #9 of 23 (permalink) Old Dec 5th, 10, 05:20 PM Thread Starter
Clint
Thanks for all the feedback. I don't understand what back space of the wheel means. Can someone tell me what it is and how I determine it?
The springs are multi leaf. Yes it is rubbing on the outside of the tire. The guy that finished the car left a piece of metal haning down a bit on the inside of the wheel well (both sides) now both tires have damage on the outside of the tire. Again thanks for the help.
Chigdon is offline
post #10 of 23 (permalink) Old Dec 5th, 10, 05:24 PM Thread Starter
Clint
Rubbing on the outside of the tire. I don't know what you mean by back space. What is it? How to I determine? Thanks
Chigdon is offline
post #11 of 23 (permalink) Old Dec 5th, 10, 05:26 PM Thread Starter
Clint
Chigdon is offline
post #12 of 23 (permalink) Old Dec 5th, 10, 06:49 PM
DjD
DjD's Avatar
Clint please only post the question in one forum... I went ahead and merged the two so you have all teh replys in one place...
See if this helps you understand backspacing...
https://www.rsracing.com/tech-wheel.html
...Dennis
DjD is offline
post #13 of 23 (permalink) Old Dec 5th, 10, 07:15 PM Thread Starter
Clint
Sorry about posting in 2, won't happen anymore. Thanks for the backspace info, the backspace measure 4 inches. Any help? Thanks
Chigdon is offline
post #14 of 23 (permalink) Old Dec 6th, 10, 09:22 AM
Knowing the backspacing is a good start, but you also need to know how wide the rim is so you have something to reference it to. Which would mean removing a tire and measuring the rim.
In the mean time, can you trim that metal away without damaging the car? That's what I'd be looking into first.
BPOS is offline
post #15 of 23 (permalink) Old Dec 6th, 10, 12:51 PM
Tony
71maligreen's Avatar
im running 295/50/15 but have my 68 up higher than factory so no rubbing.
what metal are you refering to that is hanging down by the tires??
heres mine
love them all corvettes,camaros,chevelles!!!
71maligreen is offline
